Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Basecoat Did Not Adhere
  #56 (permalink)
Old 09-26-2012, 11:58 AM
tech69 tech69 is offline
put up or shut up
I have to say ICAR says over and over and over and over, Follow the manufacturers recommendations! It is their line at the end of every guide line in every manual and ever class that they will say over and over, and over, and over. I went to an "Advanced systems" class once (ABS, SRS) and I wrote in the book I got from the class every time the instructor said "Follow the manufacturers guidelines" and I still laugh when I open it up as it is on EVERY PAGE.
yes I know, but they also say base coat is better with hardener, and yes I've been to the classes you speak of. I'm platinum certified at paint and soon body. I'm not here to say who's right and who's wrong or get in a pissing match, in fact, I already agreed to your notion that you stick to the manufacturers suggestion in a post earlier. Everyone is right to some degree in this thread. You don't always solve paint issues with your first guess and every wrong answer leads you closer to the culprit thru process of elimination. It could or could not be crossing product lines, but I do know crossing product lines can be done at times, and that also it can't. It just depends on the combination of products. The question is, has this combination proved to work on numerous occasions? Is just one area affected or the whole paint job? That will give you a good clue.
To be honest, I think we need to go off more clues and details to be of any more help to this fella. I think it's pretty common sense to everybody to follow the tech sheets but there's a lot of respected guys out there who cross product lines all the time. In a nutshell, I don't think any of us know enough about the paint session that led to this to automatically declare the problem is mixing product lines. It's kind of premature at the moment, for me at least, to feel confident that the problem is from mixing products. Everyone is entitled to their opinions though. How bout we get every last detail to what exactly went on including temps of spray time/cure time, even to how many flies were in the room...just for detail.
