Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Basecoat Did Not Adhere
  #61 (permalink)
Old 09-26-2012, 05:42 PM
MARTINSR MARTINSR is online now
You are right on the money Mr. Widetrack (or can I call you 69? ) what you explained is accurate but this isn't the case in this failure because the clear didn't peel off the base, the base peeled off the primer. Now, the exact occured I believe in that the primer did as you suggest or the water borne cleaner was in the primer creating that barrier. But why just in that area around the handles?
