Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Basecoat Did Not Adhere
  #63 (permalink)
Old 09-26-2012, 07:03 PM
BarryK BarryK is offline
[QUOTE=tech69;
Awesome post, and you are right! I'd also like to state I-Car also thinks your way. I'll have to remember, as you said, 1oz for each quart. I'll use that ratio for my car when it comes time to paint.[/QUOTE]
Tech69,
After seeing your work, I'm shocked you are not activating the base now, that I would blame on a bad jobber, as he should have educated you why you should or a bad paint rep.
Don't matter if you buy the base activator form the base company that you are using or if you use one of your clear activators, the most important thing you can do is use it in all your jobs, you owe it to the shop and most important, you owe it to the customer.
