Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Basecoat Did Not Adhere
  #113 (permalink)
Old 10-27-2012, 09:04 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
I have to say it does NOT shoot down the waterborne wax and grease remover not being out of the film before paint. 20% more humitity could be a HUGE factor in this. Think about it, the water in the W&G needs to evaporate, where is it going to evaporate too? Into the air is where, if that air already has a ton of moisture in it, the bus is full, it can't get on!
There is always the "perfect storm" where many very small things add up, without the extra humidity, everything else the same, no problem. With the same humidity and leaving the surface 5 more minutes to flash off, no problem. See what I mean, without the perfect storm of both these conditions, no problem.
I am not saying for sure of course, I don't know, but it can't be discounted. This was a very odd failure so the real answer is out there somewhere in the cosmos.
Your right Brian, the perfect storm needs to be recreated, the questions I would have just to start are, How wet did the product go on the test panel, How many coats of base, Was the test panel shot up right (like a door on a truck) or laying flat on the table. I could go on.
The analogy of "the perfect storm" is 100% correct because if everything was the same, the same results will happen, if the results change the perfect storm was not recreated.
Excellent post Brian, this is good information for all.
Ray
