For years with my own base, I have told hundreds of people, use ANY automotive clearcoat activator in my base, if they did not have my clear at one ounce per Mixed quart. Now, I would never say use my clear activator in PPG clear or any other clear as that is bad news as everyone has a different OH/NCO ratio that is not public knowledge. Basecoat activation is different from point, there are a limited number of choices the automotive paint company's have as far as "Aliphatic type ISO's". So that is why companies say, any activator from a clearcoat or SS urethane and never a primer type. |
It sounds as what ever you used to wipe around the door handles contaminated the area. Now the trick is to figure out what was different there. Maybe a silicone was applied to the handles to lubricate their pivot points? Maybe a silicone was used to make the handles shiny if they are of the mat black type. Maybe there was a buildup of a polish in and around the handles that contaminated your wipes.
I had a problem once with blue wipes. I had them in their original wrap and 12 of them were wrapped again into a Costco bundle. I stored them in a metal cabinet which also held unopened bottles of motor oil. The vapors from the oil had permeated the product wrappings and ruined the wipes for my use. Took me a few minutes to figure out why all of a sudden I had a problem, then it dawned on me, I used a new roll of wipes on that door. Hope you figure it out soon, keep us informed. Nothing I hate worse that when a thread as this gets forgotten and we never learn what the solution was. |
I was thinking the same thing but couldn't come up with anything that could have been done different. But you are very right, one needs to really study what could have been done differently around the handles. The mystery continues!
Brian |
Base coats have always been a mystery to me so a better understanding of them would help me be a better painter .Please excuse my ignorance but I have a few questions about them ....I've only activated base one time and until then I've never heard of it ,it was with Nason ful-base and although I've already been using for yrs The guy at the paint store asked if I wanted the activator with my order, activator?I said ,he said most guys dont use itso I tried it and didnt notice any difference. a few months ago I learned that Chroma base uses an activator I've used Chroma base for years alsoand never activated it....
So heres my question.... 1) what are the advantages to activating the base when it drys fast without it???? occationally I need to sand my base from dirt or whatnot but its hard to do because it clogs the paper so quick even after it sits overnite 2) if I activated the base would it sand better? 3) is basemaker (chromabase) a reducer??? and can it be used to reduce other bases? I know other reducers shouldnt be used with chromabase. Right? 4) will activating work on ALL bases ???? Barry ,Using your clear made me LOOK like a better painter but talking to you and just knowing you has actually MADE me a better painter..... DAM YOU...Now I'll never get to be a dentist.. |
1) what are the advantages to activating the base when it drys fast without it???? occationally I need to sand my base from dirt or whatnot but its hard to do because it clogs the paper so quick even after it sits overnite 2) if I activated the base would it sand better? 3) is basemaker (chromabase) a reducer??? and can it be used to reduce other bases? I know other reducers shouldnt be used with chromabase. Right? 4) will activating work on ALL bases ???? Barry ,Using your clear made me LOOK like a better painter but talking to you and just knowing you has actually MADE me a better painter..... DAM YOU...Now I'll never get to be a dentist..[/QUOTE] -------------------------------------------------------------- Mike, you are not ignorant, I had a call the other day from a guy and his paint jobber said, never activate base! The guy called me and I had a copy of that guys warranty for "certified shops" and it said "BASE MUST BE ACTIVATED FOR THIS WARRANTY" Mike you can only know what the jobber tells you and most you can take with a grain of salt. A little history how this started. Knowledge is king. GM back in late 80's or early 90's for $250,000 GM would approve a basecoat system for their warranty work. Well the majors all failed the first test and the first and only one to pass the second time was BASF, BECAUSE, they activated their basecoat-That was a new one, the others followed and also passed. Activation, totally changes the base as most good bases have a certain amount of polyol in them that is reactive to the ISO but not a lot, so you don't want to over activate. Most bases, will handle two ounces of activator per mixed quart, some like Spies, Glasurit and SPI will handle up to 4oz but a little makes such a big difference all you need to do is use 1 oz per mixed quart as a standard and that way there is no risk of over activating witch will cause the base to stay gummy. Here are the benefits. Better adhesion from base to sealer or primer. Base may or may not sand better, depend on type of CAB's used to Make base. Base will be stronger. Base will be less likely to wrinkle if you need to get back into it. Clear will stick better to base. Base open time before clearing will expand. Base will have better holdout from UV because of the ISO. Less likely to stone chip. Your choice, buy the diluted activator the paint company sells for easy measuring or use ANY clearcoat urethane activator at 1oz per mixed quart. EVERY warranty of the major high end company's for their certified shops, they all say to get the warranty you must activate. ANY job you need to live with you should activate, it costs you almost NOTHING. It is also a good way to use up old activator, I did painting around the 4th of July, lowest day was 101 and I used up my fast activator in the base, you are using such a small amount it makes no different the speed. |
| The Following User Says Thank You to BarryK For This Useful Post: | ||
cyclopsblown34 (09-27-2012) | ||
The problem with telling people to cross manufacturers is it opens the door. You say "Use such and such clear coat hardener" and the person not familiar with the chemistry HEARS "All hardeners are the same". And this has nothing to do how smart anyone is, it is all about human nature. We hear what we want to hear.
This is why I will always say FOLLOW THE TECH SHEETS! Brian |
In any case, the posts in here are great to give Brad ideas on what to look for, how detailed oriented things have to be, and a direction to start looking. Unfortunately, not all problems can be handled on-line and solved. Hope this isn't one of them. Keep us posted. |
Mike, you are not ignorant, I had a call the other day from a guy and his paint jobber said, never activate base! The guy called me and I had a copy of that guys warranty for "certified shops" and it said "BASE MUST BE ACTIVATED FOR THIS WARRANTY" Mike you can only know what the jobber tells you and most you can take with a grain of salt. A little history how this started. Knowledge is king. GM back in late 80's or early 90's for $250,000 GM would approve a basecoat system for their warranty work. Well the majors all failed the first test and the first and only one to pass the second time was BASF, BECAUSE, they activated their basecoat-That was a new one, the others followed and also passed. Activation, totally changes the base as most good bases have a certain amount of polyol in them that is reactive to the ISO but not a lot, so you don't want to over activate. Most bases, will handle two ounces of activator per mixed quart, some like Spies, Glasurit and SPI will handle up to 4oz but a little makes such a big difference all you need to do is use 1 oz per mixed quart as a standard and that way there is no risk of over activating witch will cause the base to stay gummy. Here are the benefits. Better adhesion from base to sealer or primer. Base may or may not sand better, depend on type of CAB's used to Make base. Base will be stronger. Base will be less likely to wrinkle if you need to get back into it. Clear will stick better to base. Base open time before clearing will expand. Base will have better holdout from UV because of the ISO. Less likely to stone chip. Your choice, buy the diluted activator the paint company sells for easy measuring or use ANY clearcoat urethane activator at 1oz per mixed quart. EVERY warranty of the major high end company's for their certified shops, they all say to get the warranty you must activate. ANY job you need to live with you should activate, it costs you almost NOTHING. It is also a good way to use up old activator, I did painting around the 4th of July, lowest day was 101 and I used up my fast activator in the base, you are using such a small amount it makes no different the speed.[/QUOTE] Awesome post, and you are right! I'd also like to state I-Car also thinks your way. I'll have to remember, as you said, 1oz for each quart. I'll use that ratio for my car when it comes time to paint. |
Brian |
To be honest, I think we need to go off more clues and details to be of any more help to this fella. I think it's pretty common sense to everybody to follow the tech sheets but there's a lot of respected guys out there who cross product lines all the time. In a nutshell, I don't think any of us know enough about the paint session that led to this to automatically declare the problem is mixing product lines. It's kind of premature at the moment, for me at least, to feel confident that the problem is from mixing products. Everyone is entitled to their opinions though. How bout we get every last detail to what exactly went on including temps of spray time/cure time, even to how many flies were in the room...just for detail.
as I always do. As I said to Barry, when you tell people to go out of the tech sheets and mix products it opens the door for craziness which is exactly why manufacturers are very clear on stuff like this. The problem is most likely as discussed, the wax and grease remover, or the primer being "sealed". We may never know in this case. Of course there are all kinds of times when you can, hell, there are many products that are made in one factory and labels from a number of different distributors are put on them thus making them "different brands" when in fact they are exactly the same. Or "toll manufactured" where it's raw form is made by one company and then modified by the end companies that market it. So there are times when products could be interchanged. It's just best to follow the tech sheets and that is the recommendation I make and want to make clear to all who read on these forums. You stated that ICAR says use it I just wanted to make clear to all those who just read that this is only half the truth. They say to use it it's recommended by the manufacturer. I did NOT post my last post to argue, I posted it to make sure all who read this have the facts. Being you have been to all the ICAR class's you certainly would agree that is what they say, so there is no argument. Brian |
peeling paint
I have been an automotive paint rep for 30 years. In the majority of times a peeling problem comes into the equation the problem is flash times. If you use a waterborn product or solvent flash times are crucial. It doesn't matter how long the manufacturer says paint should dry or how long you let your basecoat dry what matters is, is it dry? Slow reducer, cool temperatures, low hiding colour, side panels coming off in sheets all these tell me that the base was not completely dry. It may feel dry, however top panels will dry quicker than side panels as evaporation moves up, side panel would obviously take longer to dry. If not dry and clear coated with the clear coat using a catalyst (hardner) the clear will not just dry, it will cure. What happens to all the un-evaporated solvents in the base coat??? They want to come out, but the only way is to take the clear and in some occasions the base with it. Easy test...peel some clear coat of a painted panel, if you can smell solvents that means the solvents where trapped between your base coat and your activated cured clear coat. How to avoid the problem in the future??? We sweat to cool us down, if you like your finger and stick it in a breeze is it cooler? Same thing with paint, solvent or water born on metal has the sam effect. Feel your painted panels and feel the side of the both or a panel that has paint on it bit not recently repainted. They need to be the dame temperature. When they are. give your base another few minutes and continue with your next coat and avoid putting heavy coats of base on "low Hiding) colours, your only slowing your process down and asking for problems like this. hope this helps...69widetrack
| The Following 2 Users Say Thank You to 69 widetrack For This Useful Post: | ||
BarryK (09-26-2012), cyclopsblown34 (09-27-2012) | ||
Wide-track, you are a 110% right, from what i see in the last ten years as the polyols have gotten so good it is 99% of the time what you said and the other problem is people that drop coat their last coat of metallic and then a year later they get a stone chip and here we go, start peeling the clear off.
Great post! |
| clearcoat/ basecoat | hank | Body - Exterior | 8 | 09-26-2012 10:27 PM |
| Omni basecoat | mitmaks | Body - Exterior | 2 | 07-22-2011 08:11 PM |
| Basecoat Imperfections | nova69 | Body - Exterior | 9 | 04-17-2007 10:21 AM |
| Green basecoat ? | fire_hawk108 | Body - Exterior | 0 | 03-14-2007 10:36 PM |
| Basecoat Lapmarks | Ken's 39er | Body - Exterior | 8 | 08-11-2006 05:45 PM |
