You got the right attitude,Brad.
My typing skills have doubled ,I can type with two fingers now. |
Man !!!! It takes me a minute to type a word !!!! LOL
![]() Jester
![]() Wish you the best: Jester |
Doing a bit of fall cleaning and came across my test panel that I shot. I had forgotten to update you all on the results.
I shot the test panel using the same conditions as the doors. It was 4 degrees cooler and 20% less humidity, but that was about as close to the same conditions as I was going to get. The paint stuck perfectly fine to the test panel. I had let it cure overnight, and starting with painter's tape all the way to the good "200mph" duck tape and it stuck fine, even on the corners. I had left a piece of duck tape on it for the past couple weeks (forgotten about it), just pulled it off and it was fine. That shoots down the waterborne not drying theory, at least to me. I have decided to start keeping records of the conditions and details when I paint just in case something like this happens again. All things considered I got lucky this time (plenty of material left and plenty of time left to reshoot), but I know that won't always happen. |
I have to say it does NOT shoot down the waterborne wax and grease remover not being out of the film before paint. 20% more humitity could be a HUGE factor in this. Think about it, the water in the W&G needs to evaporate, where is it going to evaporate too? Into the air is where, if that air already has a ton of moisture in it, the bus is full, it can't get on!
![]() There is always the "perfect storm" where many very small things add up, without the extra humidity, everything else the same, no problem. With the same humidity and leaving the surface 5 more minutes to flash off, no problem. See what I mean, without the perfect storm of both these conditions, no problem. I am not saying for sure of course, I don't know, but it can't be discounted. This was a very odd failure so the real answer is out there somewhere in the cosmos. Brian |
Well Brad paint can be a tricky mistress and you have had a bunch of "could it be this" information. The good thing is that the experience you've just gone through makes you a better, more informed painter. By posting it on this forum you've given us all more knowledge and for that I thank you.
Thanks again and best of luck in future paint projects Ray |
The analogy of "the perfect storm" is 100% correct because if everything was the same, the same results will happen, if the results change the perfect storm was not recreated. Excellent post Brian, this is good information for all. Ray |
While that is true, would I go from peeling off in layers to good adhesion with a 20% drop? If it was wet enough to not get adhesion on basically a 12"x12" square, I would think I would still get some adhesion problems if it did dry faster, even if not as severe.
I recreated to the best of my knowledge. Same number of coats, through pearl and all, and pearl measured out the same. I wonder if the problem isn't something I am consciously aware of, such as there being sanding dust left there, silicone from the door handles, something to that effect as mentioned earlier in this thread. |
Brian |
All Brian and I are saying is that what happened on the test panel is different due to one of the many variables you can experience when painting. One thing that I think you can rule out is silicone being the problem. If silicone was that concentrated that it wouldn't allow paint to stick, you would have had more fish eyes in the surrounding area than you could imagine. Another being sanding dust...can't see that being the issue for many reasons.
I've been painting for many years (over 30 years) and trying to solve problems for techs in body shops for nearly as long. Every once in a while you do run into a situation that defies all reasonable explanation for the information you are given. There is an explanation out there, what it is I can't give you a 100%, yep this is it answer. I ran into a situation similar to yours about 18 years ago, beat our heads into the wall for weeks, couldn't figure it out. A few weeks go by and an apprentice took me aside and asked if opening and closing the bay door while somebody was painting could be a problem, (Cold Winter day, no air make up unit to control booth temperature). We recreated this situation with a 2 minute door open. Temperature inside the booth dropped by 45 degrees and took over 20 minutes to recover. This shocked the paint but it seemed to adhere...for about 10 days. We pressure washed the test panel and the paint blew off. Will this happen every time? I don't know, as in your case, to many variables. If everything was exact in this trade, we wouldn't need forums like this, every paint job would be perfect and all would be well. It's these things that make it all interesting and enhance the learning experience. |
While I don't necessarily believe in the sanding dust or silicone either, it is likely as you say: a combination of things making the perfect storm. If the waterborne dry time was the single cause, I think I would have seen something with this test. The "perfect storm" is hard to prevent, but a single fix like giving the waterborne and extra 15 minutes is quite easy. |
That's right, Brad, forgive my harsh responses it's just me, I ask for a cup of coffee the same way sometimes, I don't mean it like a put down or anything, just pointing out something.
Brian |
Brad, it looks like you've had a mishap even these experts can't solve. Sarcastic congratulations on that one.
These guys have taught me more in the few years I've been on here than I learned in 15 years of painting in my own shop with just the paint supplier and outdated body and paint books for knowledge.
| clearcoat/ basecoat | hank | Body - Exterior | 8 | 09-26-2012 10:27 PM |
| Omni basecoat | mitmaks | Body - Exterior | 2 | 07-22-2011 08:11 PM |
| Basecoat Imperfections | nova69 | Body - Exterior | 9 | 04-17-2007 10:21 AM |
| Green basecoat ? | fire_hawk108 | Body - Exterior | 0 | 03-14-2007 10:36 PM |
| Basecoat Lapmarks | Ken's 39er | Body - Exterior | 8 | 08-11-2006 05:45 PM |
