Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Basic carb question, does stuttering mean lean or rich?
Old 01-05-2013, 05:50 AM
75gmck25 75gmck25 is offline
I have on O2 sensor installed on my SBC, and the stuttering you describe is usually due to the carb going too lean. When I was using an Edelbrock 1406 I could easily see the effect of changing step-up springs because it changed the point for the cruise to power transition. When the springs were wrong,(transition too late) under acceleration I would see the AFR go high (lean), feel the stutter, and then the AFR would catch up as the rods moved to the power step.
Bruce
