basic engine question - 305 and 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2003, 09:53 PM
I fight what you f33r!
are 350 engine parts able to be used on 305's?
Old 09-26-2003, 10:04 PM
New Member
what parts are you trying to swap? Is the 350 a four bolt main or a two bolt main? I need more info. But if you are thinking about putting 350 heads on a 305 forget about it unless they are the small chamber heads.
Old 09-26-2003, 10:53 PM
bluesman123's Avatar
54chevy's right...the General made lots of these parts interchangeable, at least on paper, but you don't always get wat you want out of it. What are you wanting to swap between them?
Old 09-27-2003, 07:34 AM
I meant, in general are there any that can be swapped to a 305 with a 2 bolt main
Old 09-27-2003, 01:24 PM
Rubberman2003's Avatar
Well in my 84 Z28, it haad a 305 HO, and i put a 2bolt main 350 in it, they told me i can swap everything bascially. The only thing i ended up using were mounting brackets. everything else is new. They said i can even use the HO heads to raise compression, but i didnt.
