Basic Info On Engine Help - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2006, 07:21 AM
AMERICAN MUSCLE!!!!!!!!!
Hello everyone. i need to know if you could build the top half of the engine before you put in the crank, pistons, cam etc. could i go ahead and install my heads and intake on the motor itself. thanks alot!!! Have a Good one.. Allen
Old 01-16-2006, 08:05 AM
oldschoolrods's Avatar
Last journal entry: Engine Compartment
No. You wont be able to get the pistons and rods in with the heads on. However if the heads need re-worked obviously that can be done before you put the bottom end together.
Old 01-16-2006, 08:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If the engine is in excellent conditon you may get away with doing that..However I have had the experience of putting fresh heads on an old engine and promptly blowing out the rings from the increased cylinder pressure...Also if you are putting in a large lift cam the piston to valve clearance needs to be checked so the valves do not hit the pistons in operation..
Just things to look at..
OMT
Old 01-16-2006, 08:14 AM
ok thanks alot guys. have a good one.....Allen
Old 01-16-2006, 04:46 PM
wildfire78's Avatar
wildfire78
You can't install the heads before the pistons and rods. The pistons and rods go in from the top as a unit. Put some rubber tubing over the rod bolts to protect your crank journals and be sure your ring compressor has all the rings compressed properly before tapping the piston in.
If you want to know if you can rebuild the heads before rebuilding the the engine, the answer is yes, but depending on the condition of the engine, it could begin burning a little oil due to blow by.
CA smog questions...engine swaps curtis73 Engine 25 11-28-2012 08:11 PM
Engine HP/Torque Tests w/13 Different Carbs.-Interesting Info. acr Engine 6 05-19-2006 07:30 AM
Engine Info Lepracaun Engine 1 12-15-2004 05:24 PM
Very useful Olds engine buildup info. machine shop tom Engine 0 05-28-2004 10:34 AM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
