Basic Spray Can set up.... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-03-2006, 04:15 PM
Last journal entry: hot rod axle
I missed your point!
Sorry dude! I missed your point on setup!
It's basically the same. The difference is most rattle cans aren't too picky about what primer they go over. Test a fender. Make sure to see that the primer you use is sandable, and be prepared to wait longer than usually to sand the surface paint because, once again, you don't have any hardeners.
Good luck....Mike
P.S. I'm not trying ot come off as some kind of pontificating "expert" here, it's that when I was in High School, I worked for the paint company that became Valspar......It was a real learning experience.....
  #17 (permalink)
Old 10-03-2006, 07:01 PM
colormecrazy's Avatar
Paintshop Dog
HHmmmm?
having trouble figuring out where to set ign timing, fast68 Engine 34 02-03-2006 06:49 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
putting a FI set up on 406 blake carstensen Engine 10 10-17-2005 06:15 PM
Blow thru turbo set up help.. 351w beemdubya Engine 5 06-02-2005 12:42 PM
Holley choke set screw lluciano77 Engine 11 08-05-2004 10:20 PM
