Basic Spray Can set up.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2006, 10:51 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
You guys REALLY didnt think anyone would ask how to set up a SPRAY CAN do you???
Someone had to be silly today, and it was my turn!!
Old 09-29-2006, 03:16 PM
Click here
Old 09-29-2006, 08:29 PM
Brian,
did you ever think about spending some time away from the paint fumes??? ROFLMAO!!! We HAVE to get you out more...
Old 09-29-2006, 08:39 PM
Wiki Edits: 31
I use 1 of the can hand handles, there cheaper than the rustoleum version and they lock inside where the cap snaps on, rather than snapping on the top. holds much tighter. I have 3, every time I misplace 1, I go to Wallmart and buy another 1, there like $1.50 whail using 1, on a model Car, I needed something from my '51 Chevy. look on the rear floorboard, there's the other 2.
Old 09-29-2006, 08:53 PM
At my industrial painter job we had 1000's of little plastic pieces to spray bomb at a time. Think they were some sort of lights used on military vehicles. We had the little snap on can covers with the trigger. It saved on the arm a little, but I liked spraying better without them. Either way my wrist was killing me after spraying a few tables worth of those things. Must have been a slow day been away to ask this question. But I was dumb enough to look, Okay what is this all about? LOL.
Old 10-01-2006, 11:00 AM
It was just a poor attempt at humor. I felt like spicing it up a bit.
Old 10-02-2006, 05:18 PM
colormecrazy's Avatar
Paintshop Dog
If I may add!
You must also shake it up real good. This makes the ball inside the paint can bounce around. Therefore, agitating the paint thorough. That's just my opinion, and how I do it.
Old 10-03-2006, 10:38 AM
cruzinTLT's Avatar
Lovin' The Cruzin'
That's why I keep coming back to this forum---you guys are so much fun
By the way, this is my 100th post
Old 10-03-2006, 12:08 PM
Hey TLT -
No thread robbing!! This is a HIGHLY informational thread!! LOL
Suprised no one mentioned it, but for the best application, output of can MUST be pointed at object to be painted.....
Old 10-03-2006, 12:44 PM
cab cab is offline
I used the preval setup when I painted under the hood and the jambs of my 82 Firebird (including the hood, fenderwells, etc.). I had the car painted locally, and was doing a color change. To save cash I did the jambs, and underhood myself.
I used an enamel with a hardener if I remember correctly (it was 10+ years ago). I do remember thinking "Man this stuff stinks" ( I did end up using a respirator mask ), and "this stuff covers so much better than rattle can paint". Years later when I sold the car it still looked great underhood. The worst thing about the preval system was the nozzle pattern - a relatively small circle (although fine in the environment I used it for). Duplicolor cans seem to have that "special" nozzle with a wider cigar style pattern. You could probably pull one of those off, etc.
Later,
Chris
Old 10-03-2006, 01:10 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Dat does it.....no brownies for BeenAway2 long for a week! Now where did I put all 6 of my spray can trigger handles? Hmmmmm.....
Old 10-03-2006, 02:45 PM
No brownies??
Whats a guy to do??
Old 10-03-2006, 03:31 PM
Last journal entry: hot rod axle
What's wrong with rattle cans????
So.....we're all having some fun here, but I've painted a ton of motorcycles with rattle can, and even as we speak, the right front fender, and half of the hood on my station wagon/tow car is rattle can black testing how well it will stand up to the Texas sun. Maybe I've had too many brownies too.......
Old 10-03-2006, 03:56 PM
Hey, if Hot Rod can run a 5 page article on painting with a spray can, there really must be something to it and a lot to know and skill required. I can't see anything on spray can setup though in the article.
ID:	15356   Click image for larger version
Old 10-03-2006, 04:07 PM
Rattle can confusion
Seriously, before we go too far, I do know two things about rattle cans that can be a problem when it comes to expecting a decent paint job.
One, maybe the most important, is that there are no hardeners in rattle can paint, because you wouldn't be able to get it out of the can. This can make for some delicate painted surfaces.
Here in Texas, we've learned that rattle can doesn't hold up well to the sun, and fades quickly, not a problem if you're using flat, but your gloss will go away sooner than you'd like.
The other problem is the small fan size. Not a problem on small parts, and small areas like stripes or lace or other tricks, but on large areas like fenders and hoods, you're going to start having stripes like a Zebra.
I've painted cars with rattle cans, and Yes, it's cheap, and yes, you can do it on your driveway without ticking off the neighbors, but it's gonna look like rattle can........Try it, what do you have to loose? If it doesn't please you sand it off! Good luck.....Mike
having trouble figuring out where to set ign timing, fast68 Engine 34 02-03-2006 06:49 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
putting a FI set up on 406 blake carstensen Engine 10 10-17-2005 06:15 PM
Blow thru turbo set up help.. 351w beemdubya Engine 5 06-02-2005 12:42 PM
Holley choke set screw lluciano77 Engine 11 08-05-2004 10:20 PM
