Basic Starter Wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 11:03 AM
To see a diagram on a Basic Starter Wiring go to www.ss-restoration.com. It also provides part numbers for the starter and ignition switch. Pretty cool. Hope this helps!
Old 08-22-2012, 05:32 PM
How do I hook up and run engine in a 1966 Dodge truck with a flat head 251 CI engine? I just want to run engine for now. truck has a distributor, coil & ignition coil resistor.
Thanks for your help.
Bob2
Old 08-22-2012, 06:36 PM
Hoptup32's Avatar
That starter diagram on ss-restoration.com doesn't look correct.
The HEI wire should go to the IGN terminal on the ignition switch and the ST terminal on the ignition switch should go to the S terminal on the starter.
The way its shown, as soon as you turn the key on, the starter would start cranking until you turned the key off.
Basic Wiring for Chevy Test Stand crazy8s Engine 9 10-19-2015 08:03 PM
Basic 3 wire alternator wiring question jdub45 Electrical 19 11-26-2010 03:27 AM
somebody please help-basic wiring issues ftpro2 Electrical 9 09-03-2008 08:00 AM
Basic wiring diagram Retired Electrical 9 09-26-2005 07:52 AM
basic wiring OLEB97 Electrical 3 07-17-2005 08:53 AM
