Basic steps to build a 34 Ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2012, 01:14 PM
Jmccrack's Avatar
Last journal entry: Inner Fender problems
I was wondering, what are the basic steps in building the car?
Chassis
Suspension
Fit body
Wiring
Insulation
Disassemble
Paint
Assemble
Upholster
Old 08-14-2012, 01:39 PM
Wiki Edits: 27
Ffr 33
Check out Facrory Five Racing 33 for based Kits' There is build log here on HR, google... arrowhead's 33 hot rod build
Old 08-14-2012, 03:57 PM
Huneycutt's Avatar
I would recommend this book by Gerry Burger. Besides being a pretty cool guy, he really knows his stuff. I found an Amazon link, hope it goes through.
Amazon.com: How to Build Period Correct Hot Rods (SA Design) (Performance How-To) (9781934709320): Gerry Burger: Books Amazon.com: How to Build Period Correct Hot Rods (SA Design) (Performance How-To) (9781934709320): Gerry Burger: Books
Good luck.
Old 08-15-2012, 06:40 AM
Wiki Edits: 27
google books
I usually use google books , I like their layout better. Go to google books and do the search for the suggested book. It doesn't have a preview , but a lot of the others listed below do You can preview(read several pages) and see if you want to add the book to your library/
Old 08-15-2012, 08:41 AM
While not 33/34 specific; our own Dewey (C-Boy) built his car from scratch and was nice enough to document it as an e-book. At the top of the page, click the E-Books tab.
Old 08-15-2012, 09:43 AM
Jmccrack's Avatar
Wiring
Thanks for the info guys but when is a old time to do the wiring. I just want to make sure t I do not have to redo something
Old 08-15-2012, 09:58 AM
1971BB427's Avatar
?? An "old time"? Do you mean a good time to wire?
I wire before paint, but after all the fab work and mockup is done. Sometimes it's easier when disassembled after mockup to get wiring through the body and frame separately, then complete them after final paint.
I like to build my own harnesses, and test fit to the frame and body. Then once it's painted they can be installed as the final assembly is done.
Old 08-16-2012, 09:13 AM
Jmccrack's Avatar
Thanks for the info. Do you insulate before or after wiring?
Old 08-16-2012, 10:31 AM
1971BB427's Avatar
I didn't insulate until everything was done, but it did cause a couple issues. I had to try to get some sound deadener up behind wiring, and remove straps on harnesses to get some stuck in place. Next time I'll wire beffore still, but wont secure it all permanently until it's insulated.
Old 08-16-2012, 07:45 PM
Jmccrack's Avatar
Thanks for the info
Ford 302 Build for 1930 Ford Model A jkeckss Engine 28 05-06-2011 10:00 PM
Timing steps please scapegoat Engine 5 04-07-2008 01:16 PM
Need some basic hop up equipment for a 302 Ford Arrowhead Engine 14 03-02-2008 07:28 AM
Steps to sanding BMM Body - Exterior 2 08-31-2006 05:18 PM
Build your own frame? Any basic thoughts? Madd Syntst Suspension - Brakes - Steering 9 11-28-2002 09:00 PM
