Basic stuff, but HELPPPP!!! (Engine startup) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2005, 11:02 PM
Ok, I'm more of a chassis and electrical guy than an engine guy. so here's my problem...... I did some upgrades on my streetrod over the winter. New intake, new Edelbrock carb, change from points to HEI and other good stuff. Could not get the new distributor in at the same spot, so re-found TDC on #1 and ran all the new wires.(double checked the wire positions) The engine won't fire. Got battery, got fuel. All new parts. Just cranks, won't even cough. What am I missing? Thanks in advance.
Old 05-25-2005, 11:34 PM
Siggy_Freud's Avatar
Do you have spark? Do you have power at the coil?
Is the HEI module hooked up to the coil properly?
Bringing history and technology together.
Old 05-26-2005, 03:30 PM
1964chevelle's Avatar
its not pink its ember red
...didya try kicking it...worked for me
Old 05-26-2005, 04:44 PM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Sound like a dumb question but!! Did you install the distributor rotor? I have over looked this once.
Steve
Old 05-26-2005, 04:48 PM
Steve
lol. As stupid as that sounds I too have once forgotten to put the rotor back on.
Old 05-26-2005, 07:03 PM
Thanks for the replies. Rotor's on, 12 volts across the coil. No fire at the plugs. Bad module?? It's a new distributor built by Dave's smallbody HEIs. I don't know how to test for that so I'm inclined to pull it and stuff the points distributor back in. One more week to make the Nats East.
Old 05-26-2005, 07:27 PM
Most modules can be tested at Autozone. Make sure that is working, and that the wiring coming off the module is going to its proper location.
Carburator Terrano Engine 10 08-07-2004 12:22 PM
Verifying engine pedigree... johnnya Engine 3 08-04-2004 07:42 PM
New Engine Selection HotRodMan Engine 2 07-03-2004 11:22 AM
Another Engine Swap Question 7skylark6 Engine 5 02-06-2004 02:17 PM
454 engine swap Hot_Rod_Faith Engine 1 01-15-2004 03:30 PM
