Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - "Basics of Basics" Control cable repair and restore.
Old 09-03-2010, 09:56 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Good info!
There are motorcycle cable lubricators that are used to get lube inside the cable sleeve and not everywhere else.
The idea is to clamp the cable sleeve end w/the ferrule into the rubber sleeve, the inner cable comes out the other end. Tape or whatever can be used to build up the OD of the type cable being worked with.
Then the lube straw tip is inserted into its hole and the lube is injected into the cable sleeve.
Cost <$10. Many bike riders will already have one around the shop.
