Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - "Basics of Basics" Control cable repair and restore.
Old 09-05-2010, 03:03 PM
dinger's Avatar
dinger dinger is offline
I've had problems loosening cables, and the wire like hinges on the old coupe hoods, I use oil and where possible, turn them with my drill, it works wonders getting the lube worked through. Wouldn't work with the switch, but where you have a flat and or a ball end, it works well.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
