"Basics of Basics" Hood hinge spring removal and installation. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2008, 08:11 AM
By Brian Martin
I remember trying to remove a spring off a hood hinge years ago, prying with screw drivers, that is the first thought for most of us, pry it off. Then how do you get it back on, pry it on of course.
Thank God for the "old guys" who know better, I had an old bodyman show me the proper way and I have found this method to not only work on hood springs but many other springs as well. It is all about control, with prying you have ZERO control, damage to you or the car is a given, SOMETHING is going to get damaged.
It's like the difference between pulling on some damaged sheetmetal with a slide hammer, or pulling it with a pogo stick or even frame rack, you have CONTROL and it "walks" out to where you want it.
The trick with the spring is to use your muscle to pull it off the hinge, and believe me, you have enough muscle. That is, IF you have the control. I use the chain off my Pogo stick which has a flat metal hook on it. Do yourself a favor and make one of these, or, just cut the last link in a three foot or length of chain into a hook and weld it to the second to the last link, there you go, you have a hinge pulling tool.
With the hinge mounted to the car, or firmly in a vice, put the hook of the chain onto the hook of the spring. I usually wrap the chain around my hand so I have real good control but honestly, you don't even need to. You simply pull on the chain and you will easily over come the spring stretching it out and pulling it off the hook on the hinge, then slowly release your pressure on it and take it off the hinge with your other hand, it is that easy. I am not kidding, it takes much less effort to do this than you would have ever imagined.
Putting it back on, do just the opposite, hold the chain with the hook hanging about a foot down. Hook the spring onto the the end of the chain and pull the chain tight while you put the other end of the spring on the hinge, pull the chain stretching the spring until you can hook it over the hook on the hinge, there you go, it's on!
Think of CONTROL the next time you are removing a trunk spring, or any other spring and you will find that this thought about CONTROL will it off or on with a lot less loose teeth and busted knuckles.
Here is a close up of the hook on the spring.
The Following 2 Users Say Thank You to MARTINSR For This Useful Post:
64SS327 (09-18-2014), John long (09-18-2014)
Old 11-24-2008, 10:48 PM
58lincoln's Avatar
Last journal entry: New (used) 350.
Sweet! This is just in time! I planned on doing hinge work very soon. No more busted Knuckles. Thanks- 58lincoln.
Old 11-25-2008, 06:55 PM
hinge
This will help greatly. Have had springs off and on many times with panel alinement. I was trying to figure out how I was going to do it once it was painted.
Old 02-14-2012, 02:43 PM
I just wanted to bump this thread to the top, it is simply too valuable to not bring it out of the dark once in a while.
I just installed the newly powdercoated springs and hinges on my car after painting it. The inner fenders and all were also all painted off the car. I had to hold the extra chain with my left hand so they didn't scratch anything. I literally put the spring on the hinge with my right hand while the hook was hooked on it, while holding the extra chain with my left pulled very effortlessly with my right hooking the spring onto the hinge. It is so friggin easy!
By the way, just in case I put a folded up blanket on the windshield, it's easy but I'm not stupid.
Old 09-18-2014, 08:58 AM
bought a Hood spring tool
i just bought and used an automotive hood spring tool from a web site. IT WORKS AWESOME. So easy you use a wrench to stretch or release spring on or off hinge. can do it on the car too. Must check it out. here is site - HoodSpringTool.com . pretty easy to remember too. That is all they sell
Old 09-18-2014, 11:45 AM
Originally Posted by pman View Post
i just bought and used an automotive hood spring tool from a web site. It works awesome. So easy you use a wrench to stretch or release spring on or off hinge. Can do it on the car too. Must check it out. Here is site - hoodspringtool.com . Pretty easy to remember too. That is all they sell
spam, spam,spam, spam,spam, spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spamspam, spam,spam, spam,spam!
Old 09-18-2014, 11:54 AM
Martin SR's reply
Yo Martin SR, why did you reply in such a way? I am not spam! Could you of wrote it more? I am happy as sh** with new tool and just wanted other people to have a safer way than you are telling them. Your way is not safe... Mr. Control..! Tools designed for a specific purpose are way better than afro-engineering which is what your way is SR. Have a great day buddy! And good luck to you
Old 09-18-2014, 12:12 PM
Sorry, it looks like spam. It's classic spam, it's your first post, SPAM, it's an old thread dug out with a search mentioning hood springs, SPAM.
It screams
If I am wrong, I am sorry. But honestly, it's a neat tool but unneeded, the method taught to me works just fine.
Old 09-18-2014, 12:25 PM
Banned
it's a car forum. do it right..
Old 09-18-2014, 01:02 PM
spring tool
LOL That is the best picture man. Spam mmm! No but really just got tool and finally put on regular tension springs on my 68 camaro. I bought car with a fiberglass hood and put on a factory steel hood. Never would stay open after that. Now it is how it should be. Sorry i usually don't post on sites, i just read to get answers for problems. So with that said i hope we are on the same page now Brian! Thanks for all your help with stuff. Peace man!
The Following User Says Thank You to pman For This Useful Post:
MARTINSR (09-18-2014)
Old 09-18-2014, 06:16 PM
ogre's Avatar
the 'Duracell Project'
now i'm hungry
Old 09-18-2014, 08:09 PM
It's all good.
And YES I love Spam! I think I need to get a can for a lunch over the weekend. I'm thinking Bacon wrapped Spam! Oh yeah!
Old 09-18-2014, 08:46 PM
Too Many Projects's Avatar
A few beater muscle cars
Last journal entry: continued
I live in the land of spam and I hate it !!! Had to eat that excrement as a child and STILL hate it.
As for hood springs, I just clamp a vise grip on and pull...
The Following User Says Thank You to Too Many Projects For This Useful Post:
Old 09-19-2014, 06:45 AM
Last journal entry: Still running strong
What I've done to get a hood spring off is to use a hand full of body washers. Jam as many as you can between each coil. Then push the hood down enough to where you can still remove the spring. I have a 3 ton roll under jack that I used to extend the spring so paint would go between the coils. I hooked one end on the spring to the base of the jack, between the front wheels an hooked the other end to the pad then streach out the spring then paint.
Old 09-19-2014, 10:00 AM
ogre's Avatar
back to the original post... a loop of rope works well too
coming off is easy, going back on i try to have a helper push the spring into the slot
in tf trucks the line of pull there is no easy way to push the hook into the slot with the rope
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
valve spring installation and removal fordracing Engine 2 04-17-2003 12:49 PM
