Hotrodders Bulletin Board
#1
"Basics of Basics" Nuts and bolts
“Basics of Basics” Nuts and Bolts.
(Yes we are talking nuts and bolts that hold your car together.) By Brian Martin Today at work I was again reminded that not all of us have a basic understanding in nuts and bolts. I was asked to get a “10” bolt. (insert rolling eyes smilie) What the guy was referring to is a bolt that used a 10mm wrench on it. That my friends is not how you measure a bolt. A bolt is measured by the diameter and length of the threaded area. And again, there is the thread count making it “fine” or “course” thread. This is the basics right? Well, that is it, diameter, length and thread count. With those three things you can call up a store and order the right bolt over the phone. You can’t if you say “10” as your size. The “head” of the bolt will determine the size wrench you put on it. That doesn’t mean for a second that the diameter of that bolt is going to be a given diameter. You can find ¼” bolts with 7/16” heads on them as well as 5/16” bolts with 7/16” heads on them. Just as on a late model car you will find 6mm “shanks” (the threaded area) with 10mm heads (the most common bolts found on a Japanese car body) to 8mm shank bolts with a 10mm head (commonly used on the door check straps). Then we have “types” of bolts, you have button head allen “cap”, you have hex bolts, hex with a little washer built in, there are lot of different styles of bolts. Here is a little chart showing the different types. http://www.boltdepot.com/Fastener-I...Type-Chart.aspx This being the “basics”, honestly you only have to know the few that are on your car. Most likely hex holts both with our without a built in washer and a couple of different trim screws with or with out an oval head or pan head, that is about it. 99% of the average car is going to be limited to those four fasteners. And yep, there are plenty of cars out there with torx and a couple of others with more and more late model cars using these. But for most older cars the four mentioned are going to cover you. Torx is called not by a measurement but a “size’ T15, T25, etc. The Torx is a star shaped hole in the head of the bolt. There are also male torx bolts which is just the opposite. The head of the Hex bolt is measured like this, this one being 9/16 inch across, thus a 9/16” wrench is used. If it were metric it would be in millimeters 10,12,14 are common. ![]() This is where the shank is measured to determine the diameter. Again, with a metic bolt, it will be in millimeters 4,6,8, and an SAE bolt in inches ¼”, 7/16”, 5/16” etc. This one being 3/8” ![]() The thread count is measured by a neat little tool (tread gauge), this one being metric. The metric bolts threads are measured by the distance between threads in a millimeter. So you will commonly see 1.25 and 1.50. ![]() The SAE bolt is measured the exact same way, only in inches. It is measured by the amount of threads per inch. 18, 24, 28 threads per inch are common. ![]() Don’t take for granted that you are going to have “fine and coarse” threads and that is it, there are many found that are not a common thread. We had one the other day at work where a bolt was needed for the handle on a spray booth and it ended up being a ¼” bolt with 24 threads per inch, very uncommon and we didn’t have one in the shop to replace it. Some will even say this size doesn’t exist, that it is a metric 10x1.0 but that thread gauge didn’t work on it and I found 1/4x24 nuts and bolts on the net, so yes they do exist. The point being, if we would have assumed it was a “fine thread” ¼” and ran one into it, we would have ruined the threads. These measurements are for commonly found SAE and metric bolts in America. There are other types of bolts using different thread “Pitch” measurements around the world. As for “grades” or “strengths” in metric the higher the number the “harder” the bolt. And in SAE, the more “bars” on the top the harder the bolt. Notice I didn’t say “stronger”, because “hard” doesn’t mean strong, it only means hard. There are a lot of cases where a harder bolt would break because of the forces on it than a softer bolt. Basically, around the cars body which is what I am most familiar, very low grade is all that is needed, I don’t care if it is a hinge or a fender, it is going to be strong enough. While when you start talking engines and drive lines, I suggest you do your homework before you grab a bolt at the hardware store for your four bar link. Last edited by MARTINSR : 06-07-2009 at 11:24 PM. |
#2
Brian, I hope its okay to add something to this.
There's a common school of thought that stronger is always better. There's probably no area where that's more prevalent than in bolt selection. But, I recently read an article in one of the trade magazines which said the SAE (Society of Automotive Engineers) has recently issued a statement advising against the use of metric 12.9 grade (the strongest commonly available metric grade) in any automotive application unless the strength of the 12.9 is an absolute necessity as proven by engineering studies. This was prompted by all the big 3 manufacturers having experienced breakage of 12.9's which were used in applications where 10.9's were adequate, but the designer chose to spec 12.9 just for what he assumed would be a bit of extra insurance. The article was just a fairly short blurb that didn't get into the details, but it would be a safe assumption if a stronger bolt is breaking where a weaker one wouldn't, then the particular joint needs the additional elasticity of the slightly weaker bolt in order to survive. Anyway, I figured this is worth posting for anyone who's working on something with metric fasteners. The 10.9's, which are the closest equivalent to an imperial grade 8, would be most likely to be found in suspension attachments and such, so something the owner might assume to be an upgrade, like putting everything back together with 12.9's to replace the 10.9's, could in reality create a more dangerous situation rather than a safer one. |
#3
Nicely done!
Don't forget to add it to the Crankshaft Coalition Wiki compilation, if it's not already there. |
#4
sometimes harder is NOT better,,the harder they are,, they are also more brittle..making them prone to snap instead of give ,or flex.. this would make them a safety issue and certainly a big issue on suspension or any other parts that you would bet your life on...bolts snapping ,,suspension falling out at 100 m.p.h. would ruin your day ,,if not your life..
grade 3- too soft 5-8- best gr.12-too much ... .....at least that's the way i understand it.... |
Back to top |
Similar Threads for: ""Basics of Basics" Nuts and bolts"
| Suspension torque specs | scr8pin_f100 | Suspension - Brakes - Steering | 3 | 12-31-2008 06:46 AM |
| How do you keep your nuts & bolts nice during reassembly???? | shad9876 | Body - Exterior | 11 | 12-17-2007 10:57 AM |
| Nuts and Bolts - Looking For | 64Joker | Garage - Tools | 5 | 01-31-2007 11:25 AM |
| blasting nuts, bolts and other small items | Jcfoote60 | Garage - Tools | 10 | 10-13-2006 11:58 AM |
| Replacing A-arm nuts and bolts | 406chevelle | Suspension - Brakes - Steering | 1 | 05-07-2004 04:21 AM |
