"Basics of Basics" Panel alignment. (door, hood, ect) - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-03-2012, 09:51 PM
Hey gwh. I am going to jump in here and mention something before Brian gets back. I am an old Ford guy and not sure how much this applies to your Chevy. When you are mocking up the front of many old cars, Fords for sure, it is good to fit the hood first. Make sure it fits around the cowl properly. both across the cowl left to right but also around the sides of the cowl vertically. Once the hood is correct you can fit the fenders and grill as mentioned in earlier posts. When you have and old car that has a hood, like a 40 Ford, that wraps a long way down the side of the cowl there is no way allign it last.
John L.
  #17 (permalink)
Old 06-03-2012, 10:31 PM
gwh gwh is offline
Panel Alignment Sequence with other Work
John L., yes the 41 Chevy coupe does have hood that wraps down the sides. Your tip is something that never would have occurred to me. Thanks much! Guy
  #18 (permalink)
Old 06-04-2012, 06:55 AM
Originally Posted by gwh
but body NOT removed from chassis. Assume (not there yet) all body work on panels and body is done and that everything is primered, but no panels have yet been re-installed to body.
1. At what stage of painting should panels be fitted?
The panels should be fitted during the body work process, so that you can make metal work adjustments to the fit before painting, if necessary. You may have to change the contour of one panel to fit the other or what ever is necessary for proper alignment.
  #19 (permalink)
Old 06-04-2012, 07:01 AM
gwh gwh is offline
panel Alignment Sequence with other Work
Thanks, Chevymon
"Basics of Basics" Conv top pump/motor disassembly and rebuild. MARTINSR General Rodding Tech 36 07-23-2016 09:28 PM
"Basics of Basics" Sprung door repair. MARTINSR Body - Exterior 53 12-08-2015 02:54 PM
"Basics of Basics" Hood hinge spring removal and installation. MARTINSR Body - Exterior 21 09-23-2014 08:59 AM
"Basics of Basics" Rusted bolt in caged nut removal. MARTINSR Hotrodding Basics 3 11-11-2010 11:56 AM
