Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - "Basics of Basics" Rusted bolt in caged nut removal.
Old 11-11-2010, 10:51 AM
sqzbox's Avatar
sqzbox sqzbox is offline
My pipes are my music
If you could come up with a method for header pipe to cast exhaust manifold studs you would be my hero! If I had a dollar for every time I've broken the studs either tightening or trying to remove the nuts I could afford a new set of headers.
If you could post your caged nut removal process on Wiky article it would be a permanent solution that won't fade away on this thread.
