"Basics of Basics" Rusted bolt in caged nut removal. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2010, 11:47 PM
“Basics of Basics” Rusted bolt from caged nut removal.
By Brian Martin
Removing rusted tight bolts and old cars go hand in hand. There is nothing that connects you and the guy three states away working in this garage more than rusted bolts, he has them, you have them and every other guy or gal who has ever worked on old car has had them, you are a member of a club.
Tonight while removing the front fenders on my Rambler it hit me that a lot of guys would be breaking these bolts off and causing a lot of work for themselves. I figured a “basics” was in order.
There are many different methods to get out rusted bolts. These methods depend a lot on exactly where this bolt is rusted. But this one in particular is helpful just about anywhere. With a caged bolt where you can’t get to the back side to lube it, this method works like magic.
A lot of body bolts on cars have a “caged” nut on the backside. This nut is as the name implies being held by a little “cage”. The nut is usually floating around in that little cage allowing a little movement for alignment of the part or body panel. When you have a caged nut inside of rocker like in my case tonight it can be a nightmare.
The bolt in photo #1 is just one of these bolts, it is holding the bottom of the fender and going up thru the rocker to a caged nut inside. The moment I started turning I knew I had to take every precaution possible or end up with a mess.
The bolt is jammed by rust in nut and the minute you spin it the nut breaks the cage and you are stuck with a nut spinning inside with no way to grab it. Photo #2 If you just spin this bolt out the rust is going to get all jammed in the threads. Even a bolt that first turns freely will quickly become jammed up and locked tight ready to break with the next twist of the ratchet.
1. Don’t try to muscle the bolt out!
If the bolt is stuck in rust, getting bigger tool is likely going to just give you more leverage to bust the cage or bolt. This is one part of the method that came when I first started tapping holes for threads. When you tap a hole with a die you don’t just spin the die in like a bolt, you go back and forth. You turn it in a little, then reverse it out a little, then in a little, then put a little cutting oil, then turn it in a little cutting a few more threads then out, then in cutting the threads a little deeper. This is continued until the whole is threaded through.
Use the same method when removing a rusted bolt like this, the rust will flake off and not get jammed up in the threads. Turn it out until there is some resistance and change direction and tighten it back up, then loosen it again going a little further out, just a quarter turn more, then go back up in side, then back it out going just a tad more again. Each time you unscrew it a little more you are “cutting new threads” on the bolt. So instead of the rust getting all jammed up in the threads it is falling off a little at a time. Just go a little at a time. Photo #3
2. Lube it!
Now, how can you lube it you ask? The nut and top of the bolt is up in the rocker and you can’t get to it. Well, once you get the bolt out a little you spray some lube on the bolt, so now when you turn it back in you are pushing lube up into the threads! After you have turned it out and back in a few times, lube it again. Photo #4 shows just how little you can have it unscrewed and still get some lube in there.
In photo #5 you can see that it has screwed out quite a bit more. It was still VERY tight and hard to turn, but going back up and then down, adding more lube and then back up to bring that lube up into the threads it would let me turn it that little more out each time.
This isn’t a big drawn out deal. Just a couple more minutes will save you a bunch of time in the end!
Photo #6, Notice how this bolt that was installed over 50 years ago has unscrewed out of it’s caged nut without incident. You can see the rust piled all over the bolt, if I had just muscled it out I would be out there right now drilling out the broken bolt or cutting a hole in the rocker to replace the nut!
Like with all things you do on an old car, a little patience will get you a long way.
Old 11-11-2010, 09:51 AM
sqzbox's Avatar
My pipes are my music
If you could come up with a method for header pipe to cast exhaust manifold studs you would be my hero! If I had a dollar for every time I've broken the studs either tightening or trying to remove the nuts I could afford a new set of headers.
If you could post your caged nut removal process on Wiky article it would be a permanent solution that won't fade away on this thread.
Old 11-11-2010, 10:41 AM
Thanks for posting some good information...good job. I ran into this very thing, and "strong armed" it. Well, that distorted the little cage that held the nut, so the nut just turned freely. Fortunately, the caged nut was in an accessible spot (barely accessible), and I was able to repair it.
Old 11-11-2010, 10:56 AM
Actually the trick to the header bolts is heat. I am going to write up a Basics on it and how to use the heat. I have asked Jon not to put my articles in the Wiki because I don't want them altered. Anyone is free to use all the info they want just don't copy and paste my article please.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
"Basics of Basics" Trial fitting parts MARTINSR Body - Exterior 4 02-23-2008 09:33 AM
bolt removal arch General Rodding Tech 25 04-29-2004 10:59 AM
Bolt Removal HELP!!! badriand Body - Exterior 6 04-09-2004 12:40 PM
Best Option For bolt removal. jamnut Engine 8 09-09-2003 10:00 PM
