"Basics of Basics" Spot welds, removing welded on panels. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-06-2012, 06:52 PM
put up or shut up
great thread. There's a lot of planning that goes on when cutting out big stuff and if you plan wrong you're making a lot of work, if you plan right you're doing less work.
  #17 (permalink)
Old 08-07-2012, 08:26 AM
That is one of the things that people will overlook, that there is some work that saves other work from needing to be done. It's a simple concept that we will often be blinded to.
  #18 (permalink)
Old 08-08-2012, 08:37 AM
gto_ron's Avatar
thanks Brian
I've been doing it wrong for years, caused myself a lot of extra work.
Ron
"Basics of Basics" Panel alignment. (door, hood, ect) MARTINSR Body - Exterior 18 06-04-2012 06:01 AM
"Basics of Basics" Conv top pump/motor disassembly and rebuild. MARTINSR General Rodding Tech 32 05-01-2012 12:09 PM
"Basics of Basics" Moisture shields behind trim panels. MARTINSR Body - Exterior 11 07-17-2009 11:30 PM
"Basics of Basics" Moisture shields behind trim panels. MARTINSR Interior 1 07-16-2009 01:46 PM
