Continued....
So what I do is come from the other side as in photo #28. Now, to get the splitter down in there I simply strike the side of the too with a hammer pushing it in. This is where the grinding of the sides of the tool come into play. Yes I am hitting on the sharpened edge and that will dull it. It isn’t razor blade sharp and if it gets dulled a little it won’t make one bit of difference in the function of the tool. Besides, one quick pass with the grinder and it’s sharp again. Like I said earlier, I don’t like to miss-use a tool like this. But it works so darn good I have to look at it as a “consumable” like a throwaway paintbrush. If I need to throw it away, I will and buy another for the next job. But it hasn’t worked out like that as I have used it for decades. At this point a light tap with the hammer sends it in between the layers so I can then strike the splitter at rear of the handle like a chisel and split the remainder of the spot weld without tearing the metal. (photo #29) ![]() ![]() What if the weld is bigger than the drill bit? How about one of those old welds on a vintage car that was done by a man holding the spot welder on a Monday morning after a weekend of boozing (you know that really does happen) and the spot welder got moved during the weld so it isn’t round but oblong shaped. Well, by drilling a few pilots as in figure #14 you can make a long slot in the upper layer of metal removing that stubborn odd shaped weld. ![]() Drill out the metal and weld in each of those spots as in photo #15. And you have a perfectly “Unbolted” panel. (photo #16) ![]() Well, that should get you started. After a few welds you will get the hang of it, how much to drill is a biggie. You just drill a little and look, maybe even get the panel splitter in there and work it a little trying to separate the panels, then drill a little more when you find it isn’t enough, then check again with the panel splitter. Taking your time and splitting the panels without distorting the underlying panel is key. You can do this easily sometimes, other times not so easy and you have to hammer and dolly the underlying panel before you weld on your new one. That’s just part of the game, but if you take your time you can “unbolt” it just as you do your fenders up front. The more time you spend on splitting the panels the less time you will have to spend on cleaning up and straightening the metal. Now go take that body apart! |
| The Following User Says Thank You to MARTINSR For This Useful Post: | ||
John long (08-06-2012) | ||
This is such a good write up! I like articles that explain how we do it, with pictures, and why.
One question, I have only been able to find the Blair spot weld saw in my local body shop suppliers. What are the sources on some of the other spot weld saw brands you mentioned? I have found that the Blair saw sometimes skips around as you start to enter the metal with it, and drilling the 1/8 pilot hole really reduces that tendency. Also, if you are reusing panels and because of welding access, you need to fill in the 3/8 hole made by the saw, before attaching two or more pieces together, do you know a source of 3/8 sheet metal plugs, or slugs to fill in the hole on the bottom panel of the weld? |
What you have described here is pretty much how I remove welds to a "T." However I have the spotweld cutter shown in 1A and find it to be almost absolutely worthless. It jumps all around and will still easily cut through both pieces of metal! In order to use it I drill a small pilot hole in the spot--just enough to make an indent, then put the cutter pilot point in that indent and it's usually enough to keep it from moving around.
I remove most of my spot welds with a pneumatic 3" cut off wheel like you showed. I like it because I think it keeps the metal underneath the most intact, but I first drill part of the spot weld out with a 1/4" bit (but don't go through the metal). This removes about half of the metal to the weld then I finish off with the cutter. However, as it is with most things, no one tool or method is good for universal use, so I find myself using all of these tools and methods in the removal of any given panel. |
Your description of the Blair is how I remembered it, and I honestly didn't think they were even available anymore. Brian |
![]() Grinding the metal is loud, throws the sparks everywhere and it just so happens that the position I need to sit in or lay in is the exact position where it will throw all the shavings and metal on my arm and burn it or in my face, so then I have to contort my body somehow. I've also started wearing my respirator when doing this lately, because the smell and fume that comes off the metal really irritates me and after awhile would start giving me a headache. |
![]() I saw this trick in a Ron Covell video years ago, (VHS video if that tells you how long ago). It was in the first five minutes of the video and I could have turned it off and tossed it in the garbage as this one tip was worth the video price. It's in "Basic sheet metal working" and I HIGHLY recommend it if you want to learn a bunch more like this. Ron is a master and genuinely nice guy. Ron Covell Creative Metalworking Workshops Using the punch you knock a slug out of a piece of similar metal. ![]() You then set that piece in the hole and with a dolly behind it you tap the slug flat enlarging it's size so it holds it's self in the hole! ![]() Is that cool or what! With different thicknesses of metal you sometimes have to clean up the edges like I did this one so the slug will fit in the hole. But typically the best way is to punch a clean hole punching the drilled hole out of the metal. That way you have a perfect round hole for your slug. But it will often need a little enlarging with a rat tail file to accommodate the slug. Brian |
Brian, I have found that if I drill the hole 1/64 larger than the hole plug, it works good, although just tight enough to hold it. And the I have to use the step drill bits to get a round hole.
![]() NOT these (my opinion) ![]() I have a number of pairs so I don't have to hunt for one if I have misplaced it. And so my kids can put them on if they are in the garage. But my absolute favorite are the ones with the radio. They are about $50 and I feel well worth it. I use them when mowing the lawn, I can go on working listening to my baseball games or what ever, they are THE way to go for me. ![]() Brian |
So a rat tail file is usually what I will chose. But yes, especially if you are doing a number of them, go buy a friggin drill bit a 64th inch larger, that would be the way to go.Brian |
And by the way, there is NO WAY after owning that Roper Whitney I would be doing fab or restoration work without it. That and the Roper Whitney "Jr" a smaller version with different sized punches, they are worth their weight in gold if you ask me.
Brian |
I do have the Ron Covell videos, and have been to a few of his seminars at Clackamas Community College, in Oregon City, Oregon. He is a good guy, very knowledgeable, nice, and does not speak down to anyone, in his seminars. go to one, you will see. At least the videos I have from him are on DVD.
I have heard of the Whitney Roper punch, and even looked into getting one. Unfortunately, the 7A "junior" is not recommended for sizes larger than about 5/16, so I would need the next larger size of punch, and that was about $200, when I finally found one. That is a little spendy, but I think I am going to have to "bite the bullet", and get one |
And if you ever wanted to punch other shaped holes they have the dies for that too!
Roper Whitney - Quality Sheet Metal Fabrication Equipment I picked up the Jr at a garage sale for only ten bucks or something I forget, but it was a killer deal. Bought the XX years ago and never regretted it. Covell, oh heck yeah that guy is so friggin easy going. I wish I had his people skills but they are all natural to him. My brother and I had just did your run of the mill hot rods never any real fabbing. At a Grand National Roadster show (when it was in Oakland, damn I miss it) he had just started doing his classes, this was about 1989? My brother and I were talking to him next to a beautiful A roadster that he had there on display in bare metal. We were drooling over it and basically telling him how we wish we could build such a car. He looked at us and said something to the effect of "You can, I am not special, you can do it just as I did". It blew us away and I am not kidding you, we left that meeting with Ron different people. We went home and built a very special car, a super detailed very special car and I KNOW Ron had a big hand in making it happen. All from his nudge that he gave us that day. Very cool guy, he is one down to earth ego-less genuine guy that is for sure. Brian |
| "Basics of Basics" Panel alignment. (door, hood, ect) | MARTINSR | Body - Exterior | 18 | 06-04-2012 06:01 AM |
| "Basics of Basics" Conv top pump/motor disassembly and rebuild. | MARTINSR | General Rodding Tech | 32 | 05-01-2012 12:09 PM |
| "Basics of Basics" Moisture shields behind trim panels. | MARTINSR | Body - Exterior | 11 | 07-17-2009 11:30 PM |
| "Basics of Basics" Moisture shields behind trim panels. | MARTINSR | Interior | 1 | 07-16-2009 01:46 PM |
