Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - "Basics of Basics" Sprung door repair.
  #19 (permalink)
Old 01-23-2012, 04:09 AM
tbrown8338 tbrown8338 is offline
doors on my 49 chevy
Yes that's correct Dan. And it doesn't take a "sprung" door to use this trick. During a simple door alignment you can fine tune, or move a door past where the alignment movement is little you. And it works on hoods and trunks as well.
see what you can do with this brian. my doors are fine except about 4-6" from the bottom they stick out. check out the photos
ID:	62120   Click image for larger version
ID:	62121   Click image for larger version
ID:	62122   Click image for larger version
ID:	62123   Click image for larger version
