bastard frame clip - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2008, 05:33 AM
theccrider's Avatar
always proceed, go forward
bastard frame clip
i'm doing an off the wall clip with a 66 bronco frame grafted onto a 71 ltd front clip and was looking for some input. both frames are tubes and the graft has gone well but i'm on the fence on whether to fish plate it. the conections are but welded and the transition is clean with 3x4 box tubing.
66 drop bronco, chopped 4 inches
460, c6, versailles rear, 3.50 gear
the trans mounts at the bronco frame and the engine on the ltd. with this set up do you guys think a frame skid plate under the splice would suffice as the motor trans bridges the gap between the two adding some torque (ie 485 ft lbs) transfer/resistance? I hate the idea of over engineering this to the point of making and ugly overweight connection.
ps the joints were mig welded.
Old 07-22-2008, 08:28 AM
31 five window
Last journal entry: grill and rear end
I don't know your capability,but from what you have said it sounds like you know what you are doing. If welded properly and not grinding all the weld off,a diamond shaped fish plate under the frame splice is all you need.
Old 07-22-2008, 08:08 PM
The Maintenance Geek
Agreed, But if you're going for the anal build, diamond fish plates
over every weld is the way to go...
K
Old 07-22-2008, 08:19 PM
life is a temporary assignment
I like to make the clip look like it was never changed !!!!!
This is a 57 frame with a camaro clip,I welded the two frames together,Then box it.....
59 Chevy pickup frame woes! Li'l Pine Suspension - Brakes - Steering 33 07-08-2009 08:24 PM
frame pics willowbilly3 Hotrodding Basics 6 12-08-2006 10:25 AM
Help with the PREP of my frame?? Bud's 27 T Touring Body - Exterior 3 05-02-2006 08:43 PM
Frame Mod question johnnymopar General Rodding Tech 18 04-12-2006 06:24 PM
Frame front clip swap???? Old Timer General Rodding Tech 15 03-14-2006 10:19 PM
