Batteries - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2007, 11:18 PM
Northstar John's Avatar
Batteries
Hi Guys:
Just spent the last hour and a half reading all about using two batteries wired in parallel. I'm in the final assembly process on a 37 Ford using a Northstar and 4T80E trans-axle mounted in the rear. I fabricated everything, including the chassis, front and rear suspension, drive train, steering, all aluminum work and all wiring. Believe it or not, there is absolutely no room for a standard sized battery. However, I do have two small spaces, one on each side of the motor inside the car. Information I have gotten of this site seems to say the "Dyna-Batt"s work well, so I bought one and made 2 mounting trays. Just in case though, (cuz I'm a future kinda thinker), I Plan to install the cables for the second battery before the interior goes in, so I can add one if necessary. Hadn't thought of using an isolator though and now you"ve got me thinking. If I don't have an "Additional Load" requirement, and just want the second battery as a precautionary measure, would this be the way to go? Thanks for the help. Nstar John
Old 01-08-2007, 03:59 PM
Butts's Avatar
I've played around with car audio for the past decade and have installed multiple battery systems many times. An isolator isn't necessary. But may be good insurance If powering different circuits. One of my SPL systems had 4 Optima yellow tops powering 4 1farad capacitors and 4 amplifiers (all "0" guage wire) Never any problems, just more power reserve during high amperage loads.
Old 01-08-2007, 04:01 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I would, Providing you get the right isolator, one that will automatically switch, on both load and charge..
It will insure both battery's are in peak condition at all times!
If it is to be a "Weekend Warrior" you Could just use a switching solenoid (to boost crank in case of a slow start) and trickle Charge the second battery while it's stored..That will work also, but is not as reliable.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 01-08-2007, 10:35 PM
Batteries
Thx Doc:
The car will be shown for the first year, and then driven to rod runs and such. It won't be a daily driver, but will be driven when weather permits. Think I'll install an isolator anyway. Much simpler than having to charge seperate batteries.
dual batteries for starting darom Electrical 25 01-14-2007 06:06 PM
Digital camera's/ Batteries... schnitz Off-Topic 3 12-06-2005 07:31 PM
1984 Chevy Caprice Classic kringold Electrical 33 09-29-2005 11:20 PM
running two batteries njbloodline666 Electrical 5 05-04-2004 11:29 PM
Running two batteries on my 69 Stang Jim69Mustang Electrical 6 04-28-2003 06:04 AM
