battery acid - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2006, 06:05 PM
steve t's Avatar
ex biker, now hotrodder
battery acid
my blazer pos battery cable keeps getting acid buildup on it, any kind of spray out there to stop it, i clean it with baking soda, what else
Old 09-18-2006, 06:36 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Yeah you can get a spray for your terminals. I have lil can somewhere I bought at the auto parts place. I cant recall the name but I applied it years ago and it has lasted and lasted.
Old 09-18-2006, 06:40 PM
poncho62's Avatar
Wiki Edits: 5
They used to say, if you put a penny on it, the corrosion wouldn't happen....................
Clean it and put some grease on it.
Ontario Rodders
Old 09-18-2006, 06:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Check the battery POST..where it enters the battery..
I'll bet you'll find a small crack right at the base of the terminal..
If that IS the case, Clean it, use a little baking soda, and patch it with Hydroseal..That should stop the corrosion.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 09-20-2006, 10:42 PM
New Member
Make a thin paste with 1/4 baking soda and a bit of water and let it sit for about 10 minutes, and wipe away those nasty buildups.
Old 09-21-2006, 06:47 AM
T-bucket23's Avatar
Wiki Edits: 26
This can also be a sign of a battery that is starting to fail. If it needs to be charged a lot from teh alternator then it tends to emit more gas from the acid and corrodes the terminals. if it is more than 3 years old I would just change it.
Old 09-21-2006, 07:40 AM
daoldbuick's Avatar
try vasoline
I was always told you should put a liberal coating of Vasoline on battery terminals and connector, on new battery's as well as old, to stop corrosion and insure a good connection. Seem to wook for me.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
Spacers behind fan? moodier General Rodding Tech 14 10-06-2005 08:08 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
home anodizing??? hmmm General Rodding Tech 13 06-28-2004 04:48 AM
