Battery cable - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2005, 02:31 AM
Battery cable
Ok, I just replaced the thin 4 gage battery cable I had originally used to relocate my battery to the trunk with 1/0 cable however I'm about 3 feet short (forgot the extra few feet to the disconnect switch mounted on the rear bumper) and was wondering what is the best way to fasten the additional length of cable. Can I use butt connectors or will I lose amperage this way?
Old 03-24-2005, 04:16 AM
docvette's Avatar
Wiki Edits: 12
splice
Doc here,
You'd be hard pressed to find a "Butt" Splice for 1/0 cable....
What you can find is a bolt on clamp for 2 1/0 cables back at home depot that will go around 2 1/0 cables, then bolt tightly around them.
Next you will need about a 1 pound brick of pliable electrical putty.
After you tightly bolt the 2 together, add your putty in a big ball around the connector. (cover all exposed spots) Then with black tape, wrap the wire about 6 inches before the ball, then around the ball, and about 6 inches after. Reverse the tape direction and do it again (without cutting the tape) Do this 4 or five times.
That will do it. You will have a joint that won't heat or lose current If you do it right. If you get confused, go to the fuse box and meter for your house, follow the 2 inch conduit up and look where the power hooks up from the pole. this is what you want when your done.
Doc
Old 03-24-2005, 02:23 PM
As always, excellent advice. Thanks.
Old 03-25-2005, 05:20 AM
go to a car audio installation store they will have connectors for that size cable, if they don.t stock them, they can prder them.
Old 03-25-2005, 07:15 AM
302 Z28's Avatar
An electrical supply house will have them also, but they will be crimp connectors that require a high dollar industrial crimper. You can do away with the crimp and flow some solder in the connection and cover the connection with several layers of heat shrink tubing.
Vince
Old 03-29-2005, 09:53 PM
Old enough to know better
I like Doc's idea. Look for a U-bolt or Kearny at Home Depot. Should set you back less than $10 and you can make it up solid yourself. Low cost, effective, and durable.
Old 03-29-2005, 11:51 PM
I'm thinking of just biting the bullet and buying the proper length cable. But if I connect the two I'll go with this idea definitely.
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
Charging system info............... poncho62 Electrical 11 11-26-2005 08:53 PM
Battery cable 4 gauge ok? Marcus Electrical 11 03-22-2005 11:19 AM
Battery cable size 49dream Electrical 15 02-08-2005 12:41 AM
Battery cable bct Electrical 5 10-08-2004 12:52 AM
