Battery cable question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2013, 01:29 PM
Bob88's Avatar
I'm building a C cab and due to space restrictions, I have to mount the battery towards the back. What gauge positive cable would I need to use for a 10' run. Thanks.
Old 11-15-2013, 01:59 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
1/0
Unless the engine is a big high compression blown---
A minimum size is 1/0 for the positive.
Also run a 1/0 ground direct to the engine. Don't use the frame for the battery ground.
vicrod
Old 11-15-2013, 04:33 PM
EOD Guy's Avatar
I have used 0/0 jumper cables several times for neat long run cables. I get them for about 50 bucks for 16 feet, cut off the clamps and they are welded together for a slick run to the front.
Old 11-15-2013, 05:29 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
I would use welding cable 2/0 or 1/0 for a 10 foot run for + and - its very flexable, this may help Welding Cable - 0 AWG Cable info and sales
Even though you run a large 1/0 ground wire directly from the battery to the engine you still need to ground the body and frame and if your running an aluminum radiator its good to ground it too if its an insulated mount (rubber) it will help reduce electrolysis (corrosion) in the radiator! This is caused from an electrical charge running through coolant; electrolysis will usually occur if there is a defective or missing ground on one of the numerous potential electrical sources. Most commonly seen in late model vehicles because they have aluminum radiators the early models ran copper and brass. Never ground your electric fan or anything else to the radiator!!!
Jester
Old 11-15-2013, 05:35 PM
sedanbob's Avatar
X2 on the 1/0 welding cable - flows lots of amps and is flexible. Also agree on running the ground to the engine (bellhousing bolt works well) instead of the frame. Then run a ground from that bolt to the frame and to the ground on your fuse panel.
Old 11-16-2013, 07:30 AM
Bob88's Avatar
Thanks for the replies guys, I appreciate it.
Bob
Old 11-16-2013, 08:06 AM
Bob88's Avatar
Would this wire be suitable. Thanks.
Amazon.com: 10 feet of 2 gauge red battery cable: Automotive Amazon.com: 10 feet of 2 gauge red battery cable: Automotive
Old 11-16-2013, 10:53 AM
sedanbob's Avatar
Here's a chart comparing wire gauges and amp capacity.
Name:	wire guage.jpg
Old 11-16-2013, 11:25 AM
techinspector1's Avatar
Wiki Edits: 326
Originally Posted by Bob88 View Post
You would have to know the strand count and AWG size of the wire to compare two pieces of cable. Welding cable is more flexible because the individual wires in the cable are smaller diameter and more of them than that cheezy cable you get at Autozone or other outlets.
Welding Cable Class K
Class K welding cable is more commonly used, has 30 awg strandings and is available with a red or black jacket.
Welding Cable Class M
Class M welding cable offers better flexibility due to thinner 34 awg stranding and a more durable orange jacket.
Old 11-26-2013, 09:03 AM
Bob88's Avatar
I think this is the correct cable. Am I right?? Thanks for any help.
2 AWG Welding Cable Class K | WireAndCableToGo.com
Bob
Old 11-26-2013, 10:03 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Just want to point out that there is a BIG difference between AWG 2 and AWG 2/0 (00).
Wikipedia AWG is colloquially referred to as gauge and the zeros in large wire sizes are referred to as aught /ˈɔːt/. Wire sized 1 AWG is referred to as "one gauge" or "No. 1" wire; similarly, smaller diameters are pronounced "x gauge" or "No. X" wire, where x is the positive integer AWG number. Consecutive AWG wire sizes larger than No. 1 wire are designated by the number of zeros:
No. 0, typically written 1/0 and is referred to as 1 "aught" wire
No. 00, typically written 2/0 and is referred to as 2 "aught" wire
No. 000, typically written 3/0 and is referred to as 3 "aught" wire,
and so on.
Welding Cable Size Chart
PS.
Would someone explain to me WHY "flexibility" is a concern in this particular case?
Is the OP planning to roll his battery cables up every night?
In other words ... if we're talking "booster cables" ... I can see where flexibility would be a factor.
But for permanently secured cables ... not so much!
File Type: pdf Carolprene105CWeldingCableSpecSheet.pdf (224.8 KB, 52 views)
Old 11-26-2013, 11:53 AM
Bob88's Avatar
I guess I still don't understand the difference between 2/0 and 2 AWG. Is 2/0 wire larger ?? Flexibility really isn't a problem, just need to know which wire would be best for the length I need. Thanks again.
Bob
Old 11-26-2013, 12:57 PM
Wiki Edits: 326
Originally Posted by 66GMC View Post
PS.
It's not about flexibility.
Flexibility indicates that the cable is constructed with smaller diameter wire and more of them and that translates to more load carrying ability.
You will find that there is more area around the circumference of more tiny little wires than there is in less larger wires that would be less flexible. Smaller wire diameter simply bends easier, that's all.
This chart shows that this manufacturer's #2 welding cable has 646 wires of 30 gauge size. A 30 gauge wire is 0.010" (ten thousandths) in diameter.
Cut one of those cheezy jumper cables apart and check the diameter and number of wires in them for a comparison.
The Following User Says Thank You to techinspector1 For This Useful Post:
66GMC (11-26-2013)
Old 11-26-2013, 01:31 PM
66GMC's Avatar
Bob
Yes, 2/0 is significantly larger in diameter.
It doesn't sound like a LOT when you compare .540" to .655" OD, but have a look at the strand count.
646 versus 1290 ... exactly double the strand count in the 2/0!
Another table on that same page compares the Ampacity (@600 volts)
190 versus 300
Old 11-26-2013, 07:46 PM
Bob88's Avatar
190 versus 300
With this in mind, is the 2 AWG sufficient for a 10 foot run. Shouldn't be drawing that many amps, no ac, so radio, lights, starter draw, gauges, fuel pump that's about it.
Bob
Battery Cable Size: AmericanPackMule Electrical 5 07-08-2008 11:17 AM
Battery Cable Tbucit Electrical 10 11-29-2006 09:54 PM
Battery cable Marcus Electrical 6 03-29-2005 11:51 PM
Battery cable size 49dream Electrical 15 02-08-2005 12:41 AM
Battery cable bct Electrical 5 10-08-2004 12:52 AM
