Battery Cable Size: - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2008, 01:53 AM
AmericanPackMule's Avatar
Last journal entry: Adolessent J.R.
Battery Cable Size:
I Changed out the old #6 Cable to a New #4 Cable & New 800 C.C.A. Battery. With New Starter.
On my '73 Ford Courier... 1750 c.c. Will any harm be done?
Old 07-08-2008, 07:35 AM
T-bucket23's Avatar
Wiki Edits: 26
That is fine, the larger cable you installed will be able to handle more current. The lower the number the larger the cable
Chet
Old 07-08-2008, 08:25 AM
Battery Cable Size...
Chet
But, I'm Wondering if too much Amps, could burn the starter up sooner?
It Sure starts Faster!
THANKS FOR YOUR REPLY!
Old 07-08-2008, 08:34 AM
302 Z28's Avatar
No way, that is not how it works. The larger wire size only allows full voltage/amperage to reach the starter, the smaller wire size could restrict the voltage/amperage and not allow the starter to function at it's designed potential.
Vince
Old 07-08-2008, 09:09 AM
Battery...
Here's to you DoC, you will always be here.
All of you guys are great... But, I Still miss DoC too...
Old 07-08-2008, 12:17 PM
302 Z28's Avatar
No doubt, we all do .
Vince
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 04:01 PM
Battery Cable Grounding to Aluminum Heads?? wickster Electrical 1 04-08-2005 10:52 AM
Battery cable Marcus Electrical 6 03-30-2005 12:51 AM
Battery cable 4 gauge ok? Marcus Electrical 11 03-22-2005 12:19 PM
tv cable bracket bolt size help 39chevy Transmission - Rearend 1 04-14-2004 09:01 PM
