Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - battery cables hanger
Old 07-03-2012, 04:40 AM
75gmck25's Avatar
75gmck25 75gmck25 is offline
If you want some extra separation and insulation, and it will fit in the clamp, slit a small section of rubber fuse hose and slip it over the positive cable before you put it in the clamp. If you have multiple small wires its also a good idea to buy some of the flexible plastic wiring conduit and use it to protect the wires and keep them together. Using the conduit to contain small wires also makes the job look neater and more professional.
Bruce
