-   -   battery cables hanger (http://www.hotrodders.com/forum/battery-cables-hanger-221247.html)
raj4851 07-02-2012 07:59 PM
I'm ready to route my battery cables to the trunk using a Ford solenoid back by the battery. Is there any danger in hanging both battery cables, negative & positive in the same hanger? I have some insulated hangers that will hold both of them and probably also will hold the smaller wires that need to go back there also. Thanks in advance, Rod
EOD Guy 07-03-2012 04:04 AM
Use some elect tape to wrap the pos cable along with insulated clamps you should be ok.
75gmck25 07-03-2012 04:40 AM
If you want some extra separation and insulation, and it will fit in the clamp, slit a small section of rubber fuse hose and slip it over the positive cable before you put it in the clamp. If you have multiple small wires its also a good idea to buy some of the flexible plastic wiring conduit and use it to protect the wires and keep them together. Using the conduit to contain small wires also makes the job look neater and more professional.
Bruce
raj4851 07-03-2012 09:03 PM
Thanks
Hey guys, thanks for the input. I feel much more comfortable with your advice. I'll get started soon. Thanks again, Rod
LATECH 07-04-2012 06:42 PM
Using a ford solenoid is only rated for intermittent duty.
There is however a ford looking style solenoid, but with a metal jaket or housing, that signifies that it is for continuous duty. If you are using it to control all the power for your ride, or to run a circuit full time, get the continuous duty style, they are a few bucks more, but they are built for the specific duty of being left turned on .
raj4851 07-05-2012 08:28 PM
Thanks LATECH
Hey LATECH, Thanks for the info. Never heard of a continous duty solenoid. I'll check that out tomorrow. I'll bet my local parts store has one. Thanks again, Rod
EOD Guy 07-06-2012 03:47 AM
They use them on winches and snow plows, they make two versions that I know of......4 pole all most exactly like the Ford etc.... and a 3 pole, no "I" terminal.
LATECH 07-06-2012 06:34 AM
:thumbup: NAPA should have it or be able to get it. OR you can get one at the local RV store, they use them (or used to) on RV s
russ69coupe 07-06-2012 03:53 PM
Here's a link to one on Amazon. You can price compare at least.
Russ
302 Z28 07-07-2012 03:37 PM
Are you using the Ford solenoid to activate a GM style starter, if so you do not need a continuous duty solenoid?
Vince
