Battery Charger is messed up? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 07:30 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Alright, this is rather odd.
I was at my grandmas the other day and was top-off charging the batteries in her lawn tractor (23hp kohler powered simp, 1 summer old) and her brushhog tractor (52 Ford 8n). I do this about once a month, about 10-30 minutes each, sometimes longer when I use the 2amp charge rate.
First, I go to the simp and the charger clicks and clicks, the little ammeter going from 0amp charge rate to 10amp charge rate (thats the highest it reads) and back click click click. I check the switch, and its at 12v, 10amp.
Next, I go over to the old mower tractor (71? wheel horse, 14hp kohler) and the same thing happens at the same 12v setting. Onto the generator, same click click click, same setting.
So onto the 6volt 8n. This time when I turn it on (turn charger off before disconnecting) I put the switch over into the 6v postition. It charges like a normal, sane battery charger.
In conclusion, the charger works fine @6volt, but at 12volt the stupid thing acts like a cat in cold water. I did try 12v 2amp and didn't hear any hmmmmmmmmmmmmmm noise, and it registered 2amp and went down to basically 0 after about 5 seconds.
thanks guys,
matt
Old 02-09-2006, 11:15 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
Usually when they max out hold for a sec & drop dead there is something wrong with the battery.
Put a AM meter on it to see it its putting out.
as It cold out at the time?
How old are the bats?
You should get battery maintainers they have some solar powered from harbor fright cheap!!
R
"SlowRide66"
"Illegitimis non carborundum"
Old 02-10-2006, 12:17 AM
docvette's Avatar
Wiki Edits: 12
Doc here,
Sounds like to me, you have a short on the 12 volt side of the charger..
The transformer is primary side 120 volts, and the Secondary side of the transformer on the two outer wires is 12 volts AC, and Any outside wire to the center tap wire off the transformer will give you 6 volts AC.
The 12 volt side of the transformer will go to the 12 volt side of the switch, The center tap of the transformer 6 volt ac, will go to the 6 volt side of the switch, The center of the switch will go to the rectifier + side, and the transformer (other wire will go to the ground side.)
Your meter will hook between the + cable and the + side of the rectifier. If you have a thermal reset, It should be here also..
So look on everything in line when the switch is selected to 12 volts for a dead short.
The rectifier may have a couple of electrolytic caps in circuit also some do some don't, and the rectifier may be two in series, (1/2 wave) or 4 in series(full wave) IT all depends on the quality of the charger..
At $19.95..it might be cheaper to just get a new one though..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 09:33 AM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 04:01 PM
Battery charger John Sherrer Electrical 2 10-15-2005 06:11 PM
Home made battery charger lanierledford Electrical 6 06-15-2004 03:40 PM
Solar cell battery charger Jag Daddy Electrical 9 10-03-2003 06:20 AM
