-   -   Battery Clearance from Exhaust System. (http://www.hotrodders.com/forum/battery-clearance-exhaust-system-226057.html)
JMBO 11-13-2012 08:22 PM
Setting up the battery box under the floor boards in my "A" coupe. The box will be in the stock location (18" to 24" behind the header pipe.) The exhaust pipe will run under the box. What's the minimum clearance between the exhaust and the battery?
lakeroadster 11-14-2012 04:56 AM
The exhaust on my Tudor is about 3" from the battery. I made a heat shield out of 1/8" thick aluminum that sets about 3/4" from the battery. Haven't had any issues.
