Battery disconnect switch. - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2011, 05:19 PM
Hello. I installed a cheap Pico battery disconnect switch and THEN I read the instructions. It is installed in the middle of the battery ground cable. The instruction say "Do not install switch on vehicles with full time power demand computers or vehicles with thermostatic controlled electric cooling fans. I don't have any computer but I do have the electric fan. Can anyone tell me why? I tried getting in touch with Pico but that did not work out. Does anyone know of a disconnect switch I can use that will work with the fan? Thank you.
Old 10-30-2011, 07:03 PM
EOD Guy's Avatar
It'll work just fine....... when you disconnect the battery and reconnect you place a surge on some computer controlled circuits...... I've had a disconnect on my BMW, with lots of computer stuff, for 5 plus years now.... no ill effects and no dead battery for a seldom driven car. BTW Adv auto sells a very good disconnect for 12 bucks.
Old 10-30-2011, 07:30 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Your cheap Pico disconnect switch simply needs a fused by-pass.
NAPA #NWA 785117
That fuse will pop like a flashbulb if you forget to reconnect before cranking though.
Old 11-01-2011, 03:36 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
Sometimes electric fans and the temperature control relay are wired to the "always-hot" part of the electrical system because they can run after the engine is shut off.
IMO it serves no purpose to run the fan when the engine not running because the coolant is not circulating.
vicrod
Old 11-01-2011, 06:33 PM
ogre's Avatar
the 'Duracell Project'
^^ like he said ^^
my fan turns off with the key
Battery Kill Disconnect Switch Question TheBreeze Hotrodding Basics 5 08-05-2010 10:15 PM
Battery disconnect using latching solenoid grobb284 Electrical 0 07-11-2009 04:46 AM
wiki: Quick-disconnect rear mount battery; thanks Alittle1 Jon Electrical 0 06-12-2008 03:01 PM
Do I disconnect the battery? jjl Electrical 6 01-03-2006 09:07 PM
battery disconnect switch Marcus Electrical 6 03-18-2005 02:09 PM
