Battery drain on 1970 Monte Carlo - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-30-2007, 03:53 PM
old-bill-t's Avatar
Hi all,
I have a 1970 Monte Carlo That has a 1.4 amp. Drain on the battery. I have traced it down by pulling the fuses one at a time to the clk\ctsy\Ltr. The CLK is the clock, ctsy i think is courtesy Lights, But what is LTR and why would this call for a 20 amp fuse. The clock does not work so this may be the drain, not sure. Under this dash is no place for a six foot tall 250 lbs 70 year old man. Before i try to unplug the clock i would like to be sure that this is the problem. Anyone have any ideas. Thanks de old bill T
Old 03-30-2007, 04:23 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
LTR----Cigar Lighter
Any one of these could be a possible source of the drain---
Most likely candidate to me would be the lighter----crap in the receptical could be a path for power to ground.
Also---if you are checking the ctsy circuit with the door open---you would get a draw,----Headlight switch may also be a issue as this circuit is also grounded at the switch/dash dimmer.
Clock may be shorted????
pull the fuse with the biggest draw----doors closed---dash lights dimmed
Are you checking draw at the battery----battery--meter--pos batt cable??
Another source of a drain may also be failed diodes in the alt.
Bryan
Old 03-30-2007, 09:15 PM
old-bill-t's Avatar
Hey thanks Bryan that helps a lot. Gives me somethings to look for that i had not though of. I was using both a volt ohm meter and a test light. I could see the test light while i was still in the car. I was testing the drain at the battery. Thanks again Bill
Old 04-01-2007, 06:43 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The most likely suspect is someone added an aftermarket device on the cigar lighter that is drawing current. check that line for splices and follow it down.
Make sure all draws are off, domes, glove box, hood lamp, trunk lamp, ect..all will draw current..also be sure any power antenna is not stuck in retract mode..(unplug it) high power audio amps left on can also cause this.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Changing My 1970 Monte Carlo From A 2 Barrel To A 4 Barrel daveh Engine 2 02-20-2007 07:22 AM
What intake and carb for my 1970 Monte Carlo 350? daveh Engine 11 11-16-2006 08:03 PM
Need help please with an electrical headake bowtieorbust Electrical 15 01-26-2006 03:01 PM
Bring Back the RWD V8 Monte Carlo!! Fragzem Hotrodders' Lounge 18 10-16-2004 11:35 PM
