Battery Draining. help please - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2003, 07:21 PM
New Member
I took my car over to my girlfriends. When i got there i tried to start my car again, and the battery was dead. It still turns over just real slow, to slow to start the car. I had the alternator tested a few weeks ago and its fine, what else could it be? I think my battery is good. Im confused. Any suggestions would rock. Thanks
SOrry, this this is rubberman2003, im using the g/f's computer. I think i used the mouse wheel and went and posted in the wrong forum, could you move for me please.
Old 11-22-2003, 07:29 PM
Rubberman2003's Avatar
opps
Old 11-22-2003, 07:32 PM
poncho62's Avatar
Wiki Edits: 5
Check wiring and connections. If they are good, I would suggest that the battery is on its way out, not holding a charge.
Is something draining the battery while ignition is off? Lights or some accessory?
Old 11-22-2003, 07:35 PM
4 Jaw Chuck's Avatar
Lights were off?
— Han Solo
Old 11-22-2003, 07:36 PM
Well its did this before, i didnt leave lights or anything on. The volt gauge reads really low to. Im so confused on this...i hate wiring. How do i test if there is a draw, which terminal do i touch to which post? Thanks
Old 11-22-2003, 07:41 PM
poncho62's Avatar
Wiki Edits: 5
Put a voltmeter across battery with car running. Should read 14 volts or better. Turn on a bunch of stuff, lights etc. Voltage should stay about the same. If it does, your battery isn't taking the charge. Check the cells to see if the water level is up.
Old 11-22-2003, 08:03 PM
how do i checkt he cells? My car just started but the battery is still low, but i can at least get home in the morning.
Old 11-22-2003, 08:09 PM
poncho62's Avatar
Wiki Edits: 5
Most batteries are maintenance free these days, but you can still pry the tops off the cells on most. Look into the battery and see if the water is near the top. Some batteries, you can see through the side as it is semi transparent. If it needs filling, use distilled water from the drugstore. The water in the battery is acidic, so dont spill any on yourself.
Old 11-22-2003, 10:04 PM
Gene Neal's Avatar
Battery Draw!
With every thing off, remove the Ground Cable, then watch real close, as you touch the Ground Cable to the battery Ground post. There should be no spark. You can also put a volt / amp meter between the battery G- post and the G- Cable. How ever if you have an electric Clock that is hooked up it will show a draw (spark) my guess is that the battery is sulfated or has an internal short. In any case I would check the battery out first. Hope this answered your question, as how to till if it has a draw, on the battery -------------------------------------------------------------------Gene Neal
If not the Battery, I would check the starter!
Old 11-23-2003, 06:54 AM
adtkart@aol.com
You might need to have both the battery and the starter checked. If it doesn't crank over fast enough when warm and does after sitting long enough to cool, it may be the starter, or connection at it.
Old 11-23-2003, 10:25 AM
I took the bat. out and had autozone do a load test. The battery is good, im gonna take the whole car up and have them test the alternator when its running.
Im not 100 % sure but i think i fixed it. I hooked my Engine Tester thing, up to the battery to get an initial reading. Then i started the car and i didnt change, so i thought ALTERNATOR. I looked at the back of the alternator, where the 2 wires go on the threaded post. Well it was loose and wasnt making good contact. I tightened it up and then i started the car and the volts jumped up YAY
Old 11-23-2003, 11:02 AM
78novaman's Avatar
The AMC, FORD, & CHEVY Guy??!!
Last wiki edit: Improving fuel economy
Last journal entry: Finally on the road
Re: Battery Draw!
That is not necessarily true. My 96 crown vic (P71) always pulls current from the battery, I think because it has heated mirrors. Most older cars you can do that test with, but these new ones are weird.
Old 11-23-2003, 09:11 PM
Gene Neal's Avatar
Battery Draw
78novaman! Rubberman2003 ask a question, (How do I test if there is a draw, which terminal do I touch to which post? Thanks) In reading all the post I did not see a direct answer to the question. So I did try to answer, at lest it was a start in the right direction. Of course there are many other things that might be causing a draw on the battery. Electronic ingestion is another. In any case one would have to track each and every one down, and eliminate them, till you find may be a bar wire that is causing a small short, or a bad unite in one of the electrical circuits.
If you know of a deferent way to check this out, without having a lot of equipment, pleas, post it here, as Rubberman2003 I'm sure will make good use of it. and perhaps we all can learn a thing or two.
No affiance meant! Thanks for the reply. ----------------Gene Neal
Old 11-25-2003, 08:54 PM
78novaman's Avatar
Sorry Neal, I didn't mean for him not to follow your advice. I was merely pointing out that in my case it would be misleading to look for current draw that way, as terminals on my car spark whenever you connect them, because some accessories in it are always on.
Old 11-27-2003, 11:44 AM
adtkart@aol.com
There is one way that I know of, it is time consuming, but what isn't in electrical. Hook up a test light between the battery cable and battery. With the keys and everything turned off, start pulling fuses. When the light goes out, you have found the circuit that was drawing the power. I always start by pulling the fuses for the things that always stay on, like the radio, if it has a clock, and the interior lights, since you will have the door open any way,
