check the fusible links from the starter power stud. they feed power to the rest of the vehicle, and if your smoke was coming from below distributor...thats whats down there. good luck.
also, i had happen on my 86, there should be a black box with 2 studs on it on the firewall, towards the driver side. Seen that feed burn off as well Last edited by 86GMC; 11-13-2010 at 08:29 PM. Reason: idea #2 |
Probably smoked the alternator diodes as well.After you fix the fuse links that burnt and replace the now notworking soundsystem (sorry) check the alternator for a draw and for a no/low charge rate as the diodes are probably fried. If they pass A/C current as a result it will take out your new battery as well.Give it a good checkover when you get r done. Dont mean to be a wiseguy, just dont want you to be suprised when youfind all this out through a long and arduous process as I have seen people do.
Check the alternator, It's most likely damaged. Check all the electronics, digital clock, ignition module, radio, computer and car alarm system. I would not worry the on starter.
forgot to add, if you do end up finding the links have burned, replace them with fusible links. do NOT splice in ordinary wire, if something goes wrong in the future, you will be kicking yourself as you watch your truck burn and think back to this!
Or you can replace the fusible links with a "maxi fuse" you can get these from painlesss wiring/summit or jegs have them in stock and do away with the antiquated fusible link, and have a much easier repair of the system should another electric "issue" arise!
I will be checking all the fuses again in a few hours as well as the fusable links. Switching to Maxi Fuse may be an option. You should see these old wires, clearly Stock Wires, and they look like they took a beating. Project in the future; ReWire entire vehicle. I will return if I have any more questions, or I will start a new thread.
Thank you all for your suggestions and help. |
. But i have seen just the wires from the starter burn and everything be ok but not in every case , I just hope you got that lucky let us know what you find.Cole |
When I made a similar mistake on my '75 it burned the fusible link that comes off the junction on the firewall next to the brake booster.
Bruce |
As others have noted, replace the fusible links. I seriously doubt you've done anything to the alternator. In any case, get it running first THEN determine if the alternator is damaged or not.
battery post location
Back in the old days when the Battery posts were on the top on one side of the battery. you would face the battery and know which one was Pos. Now I get out the red spray can and spray the Pos end of the battery , There are two may vehicles on the farm to try to remember. Summer car has AC, Winter car has engine block heater, wife's sports car(good weather car), . 6 trucks, two forklifts, Tractors, Backhoe, etc..
I had a similar problem a few years ago while working on my 71' camaro. I had repainted my engine block and replaced a few gaskets. What i didn't know was after a week of work, I had got it all back together. On the first crank I saw a spark from the battery. I got up looked at it wiggled the wires and it looked on. Battery was connected properly. What I didn't see was a wire behind the battery leading to the parking lamp. odd as it seems the power wire leading into it had been exposed and on the second crank it arched out on the chassis. the entire harness went up in smoke starting from the battery and in a mater of seconds, it fried the alternator and and every wire under the hood. I almost a 24 hour period splicing each wire with a razor blade and replacing each one. To include replacing the alternator and starter. The battery was still good. But everything else was toast. Hopefully you lucked out with just a fusible link.
| Battery Life | beertracker | Electrical | 14 | 08-28-2010 05:25 AM |
| Battery continuity? | awoodman | Electrical | 3 | 05-26-2009 09:25 PM |
| battery cables | corvettetonybone | Electrical | 31 | 04-07-2009 05:07 PM |
| Spacers behind fan? | moodier | General Rodding Tech | 14 | 10-06-2005 08:08 AM |
| Heads installed backwards....is it possible? | La Maquina | Engine | 6 | 07-10-2002 04:18 PM |
