Battery isolator - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2012, 09:18 PM
Irelands child's Avatar
Battery isolator
Has anyone made up their own master switch/battery isolator using a latching solenoid? There are several kits on the market, but it looks like they all use a 100-110 amp Cole-Hersee or Ametek solenoid, either a continuous duty or latching and most are well over $100 for 50-55 bucks worth of parts, many of which I already have. I want to use the latching version as it draws no current after it's activated where the continuous version will.
Any cautions or good words/diagrams etc before I order a solenoid in the next day or so?
Dave W
Irelands child
Old 01-09-2012, 07:09 AM
Must have been too late/too early
Irelands child
Old 01-09-2012, 08:26 AM
delawarebill's Avatar
solenoid
never been down this road so i may be NO help... but what about a ford starter sol ??? what ever sol u use its gotta be energized by power by the key... think'n outloud...
Old 01-09-2012, 08:50 AM
Bill - that was my first thought to use as I have one or two clunkers around, but these have to be continuous duty or latching. The Ford is intermittent and wont survive very long. The more I read about these gadgets, the more smarter I get. Yeah, sure I do
Dave W
Irelands child
Old 01-09-2012, 07:21 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I have used latching solenoids (contactors) many times.
The main issue is it must be rated for continuous load in that application and/or inrush for starting.
the voltage source for switching control must be considered. If one battery runs dead will it be enough to switch to the charged battery? A diode isolated feed from both batteries to the SPDTCOff switch might be good idea.
vicrod
Old 01-09-2012, 07:58 PM
LATECH's Avatar
Why not run one of these, they require no current to operate(parasitic) as they are solid state.
Pardon my last picture bump.
ID:	61643   Click image for larger version
Old 01-10-2012, 07:30 AM
OK - first of all, I have to apologize for the title of the thread as it should have read "Battery Disconnect" as battery isolator in the world of these kinds of devices and designs really mean isolate one battery from a second. Like I said before, "...the smarter I get"
I finally opened my wallet and took the shot on a Cole Hersee 24200 latching solenoid. This is one that the coil operates momentarily to turn on then to turn off and with a button type switch and is rated 110 amp continuous duty. This $50 solenoid is the same one that Painless wiring uses in their $160 (Summit price) battery disconnect. Watson's Street Works also uses it for their disconnects.
To finish out, I'll try to remember to post the schematic for how I ended up wiring my car.
Thanks for the help thinking me through this mod.
Dave W
Irelands child
Old 02-27-2012, 10:55 AM
This is how I did it. It works just fine:
Including the Odyssey PC680T battery, it's all hidden behind that box with the remotely operated JVC stereo mounted on top:
The stereo box still needs to be covered - one of these days (maybe )
Somewhere an 'oops' bunch of in-progress pictures are hiding on my computer, so I may have more to add later.
Dave W
Irelands child
Old 02-28-2012, 08:24 AM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
Nice job, Dave! I will have to incorporate this into my build-thanks for sharing-
Old 03-01-2012, 02:37 PM
gto_ron's Avatar
Hi Dave
Nice drawing, I don't understand the function of the 14Ga wire. It looks like it's bypassing the 10A fuse. Fuse goes between 1 & 2, 14 ga wire goes between 1 & 2(low side of fuse). Am I misreading the drawing?
regards
Ron
Old 03-01-2012, 07:25 PM
Originally Posted by gto_ron
Hi Dave
regards
Ron
Yes, that 14 ga wire is bypassing the fuse. It's not needed.
Old 03-01-2012, 07:33 PM
That's correct. When I cleaned up the drawing for my files and posting, it should have been eliminated. I'll correct and post the revised sketch tomorrow. I'll ask the mod to delete the screwed up version at the same time Sorry for the confused copy
Irelands child
Old 03-01-2012, 08:15 PM
Last journal entry: My Last Hot Rod
I also tried the Ford
solenoid on switching battery banks from my solar panels. but they over heated after a few minutes. However I took one apart and could readily see that if the terminals and the brass disk were larger in proportion to the amps needed they would work. I was always going to machine out a 1 inch or larger brass disk and 3/4 inch brass terminal bolts and another housing etc. And see what it could do. maybe someday?? Then I thought use 3 or 4 in parallel to carry more amps but I only had the one solenoid.
Old 03-01-2012, 08:35 PM
Sounds like you needed a latching solenoid. Once energized, they don't maintain the coil current to keep the buss in place. Sounds like you have either a continuous duty or intermittent duty and with these the coil will get hot. The Ford type - that's intermittent duty and while it will work, will fail eventually. A latching solenoid will cost in the neighborhood of 50-60 bucks.
Irelands child
Old 04-16-2013, 07:38 AM
This is an awwww-@#$% which I forgot to do:
Irelands child
Battery Isolator Wire size? 67Elcamino Electrical 5 09-04-2011 12:17 PM
question on dual batteries and isolator Jmark Electrical 6 06-08-2007 09:06 AM
Battery Isolator and Inverter need cooling? 71gtx Electrical 3 06-04-2007 06:49 AM
Phenolic Fuel Pump Isolator red_rider52 Hotrodding Basics 1 03-26-2007 11:03 PM
battery/alternator/isolator question jjjewett Electrical 1 09-10-2004 01:32 AM
