Battery Isolator Wire size? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2011, 10:28 PM
67Elcamino's Avatar
In the process of installing a second battery in my truck to run my airbag compressors and purchased a 200 amp battery isolator and was wondering what size wire I should run between my batteries and isolator? I dont think the wire needs to be as big as the wire going from the battery to the starter? does it? I was planning on using a 8 guage wire between . will that be sufficient? or does it have to be a 4 guage?
Old 09-03-2011, 11:14 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
I would go with the 4 or heavier, but here is a sizing chart for you to help make up your mind.
Name:	wire size index.jpg
Old 09-04-2011, 01:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Bigger wire gauge has its advantages but can cause problems w/fitment and routing in some cases. If there are no problems routing larger wire, there's no real downside to doing so, IMO. The alternator output wire going back to the isolator (if that's the plan) should be made larger.
The bottom of page 1 shows some recommended gauge/amp ratings depending on the alternator capacity that may be of use to you. DC current "likes" more rather than less strands for any given wire gauge.
Old 09-04-2011, 08:13 AM
302 Z28's Avatar
Did your air bag compressor come with any specs about what the amperage draw is? There are tables for sizing wire per amperage draw. I would go one size AWG bigger than what is required for safety sake.
Vince
Old 09-04-2011, 10:05 AM
OLNOLAN's Avatar
Wire Size
http://www.countryhomescampers.com/p...structions.pdf
Here are instructions that cover most alternator applications. See the wire chart/breaker sizing recommendations. Make sure to use a circuit breaker. Don't make the mistake of sizing the wire off a voltage drop chart as some dudes do, it does not take wire heat/insulation temperature rating into consideration. Use automotive grade wire with the highest temperature rating you can find. Although a bit more expensive, marine rated wire from a boat store is the best. The marine cable terminals are also way higher quality than the cheap junk that most auto part stores carry. Also as others have mentioned, using one size bigger wire over the chart listing adds in a safety factor.
olnolan
Old 09-04-2011, 12:17 PM
67Elcamino's Avatar
Thanks guys
Another question I see some wiring diagrams on the Isolators state that the wire goes from one battery to islolator to the other battery instead of from the alternator to isolator to battery.. Is there a difference? if going fro alternator to isolator how do you run a 4 guage wire from the alternator? Just seems a big of an exaggeration comiing from the alternator
4ga vs 2ga battery cable, also insulation on wire silentpoet Electrical 3 04-03-2011 08:21 PM
Battery Positive Wire Routing PancakesandSausage Electrical 3 01-26-2011 10:47 PM
Battery Isolator and Inverter need cooling? 71gtx Electrical 3 06-04-2007 06:49 AM
How do I wire my trunk mounted battery?? Half Breed Electrical 33 01-29-2006 04:07 PM
battery/alternator/isolator question jjjewett Electrical 1 09-10-2004 01:32 AM
