Battery issue? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 10:18 PM
396chevelle's Avatar
Battery issue?
Ok guy's the other day I was working under the hood of my 69 chevelle. I had some tools sitting up on the fender and my boy decided to come and ask me a question, but when he walked up to the car he bumped my tools and one of the wrenches fell perfectly on to the positive and negative posts on my battery. Which took me a second to get it off maybe 2 seconds of course sparks flying. My luck go figure! Anyway, I did'nt worry to much about it at the time. So a couple days later I was going to take the car for a spin, but the car was completely dead. I mean 0 juice, so I put my charger on it, but it would not charge. I figured it burnt the battery up! I took the battery back and exchange it for a new on. I installed the new battery fired the car up and rode around all day. Now the car has been sitting up for a few days. I went out there today to crank it up, but it's completely dead again. Put the charger on it, but again it won't charge and it reads 0, so I decided to pull the battery out and put the charger on it without the cables connected. Well, It started charging the battery. Anybody know why the battery is draining while sitting in the car along with it not wanting to charge with the cables hooked up? I've never had a problem until the battery incident. I just find it odd that the battery will charge as long as you pull the cables off. Burnt alternator maybe?
Old 02-29-2012, 10:32 PM
snkbyt's Avatar
ASE Master
Last journal entry: 52 Chevy for sale
If this car is stock wiring. Look for a burned out fusible link in the positive wiring by the starter or even by the battery by the radiator support. Try stretching them and they will stretch if burned out. Best to use a test light for power to alternator. Also, If it has power to alternator then blown diodes will cause a draw and no charge.
Old 03-01-2012, 04:03 AM
EOD Guy's Avatar
As far as not charging with the cables hooked up..... dirty terminals or a direct short to the pos feed wire....... the smaller wire connected to the pos post on the battery that leads to the junction block that should be on the battery side of the radiator support, that junction is bolted to the radiator support and has been known to melt and create a short.
There should be a wire that leads from that junction, across the radiator support towards the drivers side fender, leading to a factory splice then to the external voltage regulator and the horn relay, the fuseable link is located after the factory splice and before the horn relay, should by orange in color.
Old 03-01-2012, 01:45 PM
gto_ron's Avatar
Hi 396 Chevelle
I vote for a shorted diode in the alternator. Was the engine running when you tried to weld the wrench to the battery?
I'm curious if you got it fixed and what did it turn out to be?
regards
Ron
Old 03-01-2012, 02:41 PM
Last journal entry: My Last Hot Rod
Right on
I think shorted cables or alternator. when you try to charge the battery with the cables on the dc current follows the path of least resistance which will be the short to ground. that's why it charges with the cables unhooked.
Old 03-01-2012, 05:28 PM
snkbyt's Avatar
ASE Master
If it shorted to ground it would be a pile of melted plastic from the cables let alone the smell and real obvious. It all would be fried that's what shorts do like blowing fuses. A short there is going to blow a fuse link.
Old 03-01-2012, 07:21 PM
EOD Guy's Avatar
Depending how long it was shorted brfore the fuseable link blew, if it did, would determine if the "pile of melted plastic from the cables" ..... sounds like he got if off pretty quickly, but maybe not quick enough.......
I too am intrested in what actually happened and the fix
Battery chargers can't recognize my battery? Ghetto Jet Electrical 6 11-23-2011 07:44 PM
Best 60s Issue of Hot Rod Magazine and best 50s Issue of Car Craft MXrider13 Hotrodders' Lounge 18 07-29-2011 01:55 PM
Wiring issue? Bad Battery? HELP! Vicky_65 Hotrodding Basics 11 06-27-2011 08:24 PM
confusing battery issue Dagwood03 Electrical 11 08-19-2010 05:19 PM
Suggestions for battery tray/box for a group 75 battery grobb284 Electrical 1 10-05-2009 10:28 PM
