Battery for MGA - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-17-2004, 04:05 PM
Battery for MGA
anybody here know what size battery I should use for this car? I cannot find any that will fit the battery boxes.
Old 05-30-2004, 02:15 AM
UncleFluffy's Avatar
never returns tools
There's an article on converting to a single 12V battery here that includes references to the original 6V battery sizes and part numbers:
http://mgaguru.com/mgtech/electric/electr_2.htm
Moss sells original-style 6V batteries:
http://www.mossmotors.com/Shop/ViewP...eIndexID=29407
But at $109 US each that's an expensive solution, so unless authenticity is absolutely vital to you, I'd suggest you go for the single 12V solution. You can always switch back later.
Old 08-22-2013, 06:36 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
I have OPTIMA RED top in my MGB it is small in physical size but high amperage and CCA ,if your car sits extended periods between driving go with the yellow top ,
some drivers are running two 2 motorcycle optima red they are 700 amps each very compact in size ,I think that is more than you need ,1 works fine in mine.
Old 08-23-2013, 04:35 AM
EOD Guy's Avatar
I have no idea what your battery looks like...... but the Mazda Miata battery is a small compact high amp battery that [I] have used on some applications.
Mazda MIATA Battery: BatteryMart.com
Old 08-23-2013, 07:57 AM
gow589's Avatar
the Clever Turn Signal
I run 2 odyssey AGM motorcycle batteries in one battery box in my MGB.
