Battery Myths - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-21-2004, 05:18 PM
Mollard's Avatar
Battery Myths
So does putting a battery on cement for storage or while charging harm the battery at all?
Old 12-21-2004, 05:42 PM
302 Z28's Avatar
A total myth. See the link.
http://www.inct.net/~autotips/battmyth.htm
Vince
Old 12-21-2004, 11:56 PM
Old enough to know better
That is one of the best, most accurate explinations I've seen in print.
Old 01-17-2005, 06:33 PM
New Member
BATTERY MYTH
A battery can discharge sitting idle on a shelf or on the floor, new batteries have a shelf live (theres a hint). According to the science a battery sitting on a concrete floor (always colder than the air)can discharge more quickly than the battery on the shelf because of the temperature difference, but in reality a battery doesn't know where it is therefore the material the battery rest on has no effect
Old 01-17-2005, 06:59 PM
poncho62's Avatar
Wiki Edits: 5
Myth or not, I have always not put batteries on the cement floor. Better chance of it getting damaged down there. I always put it up on the work bench...........
Old 01-17-2005, 11:19 PM
I keep mine on the floor because acid from the battery can hurt my bench a lot worse than the floor will hurt my battery. Plus, You can't fall off the floor!
Old 01-18-2005, 05:52 AM
302 Z28's Avatar
I did a few times in high school
Vince
Old 01-18-2005, 08:43 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Already been covered.
http://hotrodders.com/showthread.php...battery+cement
Old 01-19-2005, 01:23 AM
dbierman's Avatar
I keep mine in the car
