battery oxidation - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2011, 07:52 PM
mitmaks's Avatar
Last journal entry: Grille
battery oxidation
I have dual batteries on my truck but one of my batteries keeps oxidizing. i have a cleaning/protector kit that I use. however this negative terminal on one of the batteries just keeps oxidizing after a bit no matter what I do. I cleaned/sprayed protector on there, put felt spacers under each terminal.
Any ideas?
Old 08-02-2011, 03:50 AM
EOD Guy's Avatar
I use corrosion X, it's a marine anti-corrosion compound
http://www.marinestore.com/Corrosion...95108992206885
I get good results with it... last 3-4 months then need to reapply etc...
Old 08-02-2011, 07:19 AM
It's oxidizing due to a leak - that's the reason for all batteries to corrode. There are different chemical fixes out there for this and you need to shop for a cure based on how to seal the post to the case. Some fixes go on like paint. A smear of grease isn't all bad.
Old 08-02-2011, 12:52 PM
GMCTRUCKS's Avatar
Very true only a leaking battery would cause that problem.
Old 08-02-2011, 02:28 PM
T-bucket23's Avatar
Wiki Edits: 26
A weak battery that constantly needs charging will do this also. The gas that is released during charging will cause corrosion. A weak battery requires more charging so there will be more gasses present.
Chet
Old 08-02-2011, 05:25 PM
EOD Guy's Avatar
Not to sure on only a leaking battery oxidizes...... Chet is closer to the reason many batteries oxidize doesen't take much for a eltro-chemical reaction to form the gunk on the posts. Not to say batterys don't leak around the posts....... but I treat all the posts and still have the gunk after a few months etc...
rubber oxidation repair briansansone Body - Exterior 1 09-22-2010 07:07 PM
oxidation on chrome help dirtslingerrc Body - Exterior 10 07-17-2006 07:25 PM
Oxidation Blazin72 Engine 4 02-06-2006 06:52 AM
I need some help with oxidation. Church65 Body - Exterior 4 06-05-2005 05:24 AM
Carb Oxidation Halloweenking Engine 6 11-18-2002 01:03 PM
