Battery Positive Wire Routing - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2011, 09:32 PM
Hello, all.
I am trying to clean up the engine compartment on my '73 Chevy K20. I would like to run the positive cable from the starter inside the frame rail on up to the battery, in essence "hiding" it for a cleaner appearance.
In doing this however, it will run right next to the hard fuel line that runs from the fuel pump back to the fuel tank. Am I asking for trouble? Any danger in doing so? I'll post some photos later. Thanks for any advice.
Mando
Old 01-26-2011, 09:44 PM
SSedan64's Avatar
Run the +Cable inside some plastic wire loom then inside Frame to prevent a short from vibes/rubbing.
Old 01-26-2011, 09:46 PM
Commanderkewl's Avatar
Time traveler stuck here...
Sounds like you can do it as long as you use rubber coated wire clamps to secure the wiring... Unfortunately drilling the holes might be a pain.....make sure no moving suspension parts are in the way ( I know you wouldn't, it's just part of the safety and competency announcement for some readers,like me
I also put that down in case I forget
It's all about insulation....And keeping the juice from one sealed conduit from interfering with the juice in the other sealed conduit...
Did I do ok?
What part of Texas?
The 70s trucks are kewl!
Old 01-26-2011, 09:47 PM
Yeh what he said also
Trunk mounted battery cable routing mike69 Electrical 16 01-01-2011 07:14 PM
positive battery wire touching header bigtymers2g Electrical 5 04-27-2010 03:41 PM
Positive battery corrosion, Help ?? Fastest65 Electrical 6 11-24-2009 09:04 PM
edelbrock electronic choke positive wire hook up excaliberprime Engine 5 05-16-2008 04:17 PM
plug wire routing? staleg Engine 4 09-07-2007 02:56 AM
