Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - battery reloaction in truck
Old 03-31-2012, 03:14 PM
327NUT's Avatar
327NUT 327NUT is offline
As said above...you won't have any benefits other than the looks. One important thing though, make sure you run 2 BIG ground cables, one up to the nearest bellhousing bolt by the starter and the other to a clean bare metal location on the frame. Grounding problems can drive you nuts.
