Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - battery reloaction in truck
Old 04-04-2012, 04:20 PM
biohazard_81c10's Avatar
biohazard_81c10 biohazard_81c10 is offline
Originally Posted by cobalt327
Moving the battery will slightly improve the front/rear weight distribution, and can help traction a little. Nothing that you'll be able to notice by the seat of your pants most likely, but doing several things like this can accumulatively add up to a real improvement.
I tend to agree w/the idea that less weight overall is more of a benefit than a slightly better weight distribution. Less is more in this case. Once the weight is pared down to a minimum, THEN you can worry more about the weight distribution.
i have been removing as much weight of the front end of my truck but i have run low on ideas and thought the battery would be next.i thought about a front roll pan but i am not sure about the looks of it.
