move'n battery
IMHO... i don't see any benefit of the move.. other then cleaning up the engine bay.. racers move it OVER the rear axle for added wt for traction. so moving it to the front of the bed is not gonna help that much for that. but u already have the kit. just make sure u use rubber grommets through the bed and secure the cables to the frame... don't need no max spark with a short...
battery relocation
as i mentioned, i don't see a real benefit to it.. but... if thats what u want then i'm all for it... everyone has there own taste, and it sure will not hurt anything by moving it... go for it..
you would need to move it to the very rear to see any (very small) difference
however, if you can find more stuff to start moving back, it will add up |
Move it - I really dislike seeing a drooling battery, and they all do, in an otherwise clean engine compartment. Something else - why not go to one of the "dry" cell batteries, get away from that monster and almost hide it from sight. I took my big Optima out and replaced it with an Odyssey - reduced the weight and footprint by 2/3rds and only lost a minimum amount of CCA (720 vs 680 for the new Odyssey).
A couple of photos to show the difference: ![]() The tape indicates how big an area the Optima covered. I was not done wiring in this photo. ![]() ![]() Almost done here(it is now) |
As said above...you won't have any benefits other than the looks. One important thing though, make sure you run 2 BIG ground cables, one up to the nearest bellhousing bolt by the starter and the other to a clean bare metal location on the frame. Grounding problems can drive you nuts.
I tend to agree w/the idea that less weight overall is more of a benefit than a slightly better weight distribution. Less is more in this case. Once the weight is pared down to a minimum, THEN you can worry more about the weight distribution. |
i have been removing as much weight of the front end of my truck but i have run low on ideas and thought the battery would be next.i thought about a front roll pan but i am not sure about the looks of it. |
| Battery, fuse and battery disconnect switch | firstgear | Electrical | 21 | 05-17-2012 03:27 PM |
| Battery chargers can't recognize my battery? | Ghetto Jet | Electrical | 6 | 11-23-2011 07:44 PM |
| Suggestions for battery tray/box for a group 75 battery | grobb284 | Electrical | 1 | 10-05-2009 10:28 PM |
| 79 chevy truck Dead battery. | hiball | Electrical | 1 | 12-05-2005 03:25 AM |
| Where did you put your battery in your truck? | tomy2tone01 | Electrical | 6 | 12-17-2002 11:28 AM |
