Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Battery Relocation Quesions
Old 01-05-2013, 06:57 PM
hcompton's Avatar
hcompton hcompton is offline
Old & Furious
Originally Posted by farmwalker View Post
Ok I'm going to run a 2 Gauge cable for the starter. But couldn't you put a fuse back by the battery inline; because we never plan on a wire shorting out, other wise we wouldn't need fuses. Also what size wire should I use for the wire to the alternator??
Is the engine high compression?
The fuse would need to be pretty big one. Race cars use a kill switch located in the rear trunk panel so it can be access from outside the car. Also have it close to the battery. That way you can just turn the switch when you get out of the car. Also rules for most faster drag cars.
Also you can just run the alt wire to the starter relay. Do you plan to use a ford style solenoid kit on the firewall to start the car.
Allstar Performance Solenoid and Wiring Kits ALL76202 - SummitRacing.com
hope this helps.
