Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Battery Relocation Quesions
Old 01-05-2013, 09:12 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by BUFFALOBILLPATRICK View Post
Yes, use thicker wire as distance is longer.
I used 00 inclosed in a rubber garden hose inside frame. Grommet openings.
I also used a 250 amp fuse back by gel battery.
Will 250 turn the stock starter? Seems like it would pop the first time the engine hot started and turned a little slow.
If that works for you then putting the relay next to the battery will work as well. Then the heavy guage wire does not need to be hot more thana few inches past the battery.
But with high compression engine you may need to run a disconnect or a larger relay and mini starter.
